ducatipaso.org • View topic - The pickups - Hall/magnetic or what
It is currently Tue Sep 30, 2025 12:52 am
 Post subject: The pickups - Hall/magnetic or what
PostPosted: Mon Mar 12, 2007 12:00 pm
PostPosted: Tue Mar 13, 2007 7:47 pm
PostPosted: Wed Mar 14, 2007 6:59 pm
.... and those pick ups MUST be very well adjusted.... :evil:
 Post subject: pickups
PostPosted: Sun Mar 18, 2007 8:18 pm
There are two different types on the Paso's and Sports.
Two pickups in the case, and a single pickup version that mounts from the outside of the case at the 2 o'clock position with two little screws. The latter was common in the California bikes, as there is no way to adjust the timing. As mentioned, the gap is critical. The single pickup type is set with little shims. The ST2 motor is similar in regard.
The single pickup version used the Magnet Marelli 2s computer, which is a finned aluminum box under the seat with a big wire connector and a vacuum hose attached. About the same size as your voltage R/R.
Users browsing this forum: No registered users and 99 guests
