ducatipaso.org • View topic - speedo drive
It is currently Wed Oct 01, 2025 5:57 pm
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
 Post subject: Re: speedo drive
PostPosted: Tue Jun 10, 2008 8:02 pm
PostPosted: Wed Jun 11, 2008 5:25 pm
That part is also fitted to the 750ss. You won't believe this but the 'grease nipple' is fake! It doesn't go anywhere -I checked this when I had to buy a new one and had some difficulty getting any grease up/in there so I broke up the old one and found this out. What a laugh. If you want to lubricate the speedo drive then my way is to remove the drive and take off the retainer circlip and inner bush so that there is some play to the drive then drip some light oil into the mechanism. Rebuild it and wipe off excess oil - repeat every three months.
PostPosted: Wed Jun 11, 2008 8:19 pm
Yep, there sure was some shoddy machining of certain components in those days. I found on one of my DelOrto carbs that the passage from one of the choke chambers to the carb had not been drilled through. My bike starts fine using the choke on just one carb, so I left it as it was.
PostPosted: Thu Jun 12, 2008 8:25 am
Users browsing this forum: No registered users and 63 guests
