ducatipaso.org • View topic - FRONT SPROCKET
It is currently Mon Sep 29, 2025 11:02 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
 Post subject: Re: FRONT SPROCKET
PostPosted: Thu May 28, 2009 3:10 pm
PostPosted: Thu May 28, 2009 4:24 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Thu May 28, 2009 5:15 pm
I was thinking about this and came to the same conclusion. If there is any freeplay in the sprocket to the shaft, it will loosen up the bolt. the sprocket has to have freeplay, otherwise you will need to press fit the sprocket on the shaft.
Your best bet would be a shoulder bolt and use a warpy (Bellville) washer to reduce the amount of freeplay. Let the shoulder of the bolt bottom on the end of the shaft. Another method would be to make a collar that the bolt tightens down on, but does not transmit the torque to the plate. Use Loctite on the bolt threads, and a touch of grease on the bellville.
The Ducati manual suggests a thick grease on the shaft splines before you install the sprocket. As I think of this, Disc Brake Quieting grease would probably be the ideal stuff to put there. Its super thick, doesn't wander, and has a damping affect.
