ducatipaso.org • View topic - Piston from 750F1 ?
It is currently Wed Mar 11, 2026 4:53 am
 Post subject: Piston from 750F1 ?
PostPosted: Wed Jun 17, 2009 11:36 pm
Oooops
Can you use a piston from a 1985 750 F1 in a 1988 750 Paso? :oops:
I hate winter maintainance :(
Tony
 Post subject: Re: Piston from 750F1 ?
PostPosted: Fri Jun 19, 2009 2:11 am
You can use a SET of pistons from an F1. You would have to investigate if there is any real difference in the shpe, but a set should work. I think they have the same compression ratio.
