ducatipaso.org • View topic - what are these holes for ?
It is currently Mon Sep 29, 2025 10:14 am
 Post subject: what are these holes for ?
PostPosted: Mon May 31, 2010 5:20 pm
My engine has 3 holes on the back. 2 small ones are on the height of the swingarm axle (I wonder if these are original) and there`s a big one on the bottom right.
My friends Cagiva Elefant 900 engine doesn`t have any of these.
 Post subject: Re: what are these holes for ?
PostPosted: Tue Jun 01, 2010 12:14 am
Edit: Did not remember correctly....
PostPosted: Tue Jun 01, 2010 10:55 am
Are there Allen screws in there??
PostPosted: Tue Jun 01, 2010 11:22 am
it looks like there would be. Meanwhile I can“t check anymore as the swingarm and shock are back in place.
PostPosted: Tue Jun 01, 2010 2:25 pm
For two of them I would guess someone has created threaded holes for grease points to the swingarm pivot?
But I can't think what the third would be.
I don't have them on any on the various two valve crankcases I have.
Curious,
Mick
906 Paso 1989 w/ 17in wheels :)
PostPosted: Wed Jun 02, 2010 1:41 pm
I have them on my engine too. I assumed the two at the top were either for non-installed grease fittings or to clamp the swingarm axle for ?? reason. Have no clue on the bottom one.
PostPosted: Wed Jun 02, 2010 4:20 pm
ok, that`s good to now. So they are probably original. Are yours open or is there a hex screw inside ? I was also thinking about grease fittings.
PostPosted: Thu Jun 03, 2010 4:25 am
I'm pretty sure they have hex screws in them. I have a photo of the engine while I had mine apart but the resolution is not good enough to tell for sure.
PostPosted: Thu Jun 03, 2010 4:40 am
I happened to look at my spare engine and it appears that there are roll pins in the 2 small holes.... the other large one not sure what it was intended for, maybe an oil line?
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
