It is currently Mon Sep 29, 2025 10:14 am
[ 9 posts ] |
Author |
fasterdammit
Post subject: What am I getting into here, w/ the clutch ... leak? O-ring? Posted: Tue May 25, 2010 2:24 pm |
paso grand pooh-bah |
Joined: Wed Jan 19, 2005 12:00 am Posts: 708 Location: CNY, US
I haven't pulled anything apart yet, but I think something is amiss inside the clutch. I have the sinking feeling that I'll be digging it over the weekend, but I just wanted to put the 'symptoms' across you guys to make sure I'm not imagining things.
I've replaced the M/C and the line, and finally got enough pressure bled up so I can ride the bike. However, I noticed last night there were a couple spots under it that didn't appear to be oil; and there seems to be some splatter coming out of the two vents on the panel under the seat, along with some more on the frame plate near the brake footpeg. It also appears that the paint around the clutch cover is starting to flake away, it seems more so than I recall when I bled the clutch.
If the o-ring in the slave is shot, am I correct in thinking the clutch fluid is going to find its way out all around the cover (and not just through the two holes in the bottom)? And I'm only guessing the o-ring because 1) the bike is 22 years old and 2) it seems to be a popular wear item.
I do have a manual, which I haven't looked into yet (tonight) but I wanted to appeal to the collective knowledge base here before I started turning spanners. So thanks in advance. I know this is all rather vague, and I apologize ... but before I pop off the clutch cover, anything I should keep in mind?
_________________ Just because you're not dead doesn't necessarily mean you're living, either.
1988 Paso 750 #753965
1997 Monster 750
Top |
88WhitePaso750
Post subject: Re: What am I getting into here, w/ the clutch ... leak? O-ring? Posted: Tue May 25, 2010 5:00 pm |
Joined: Fri May 14, 2010 12:39 am Posts: 37 Location: USA
Just replaced O-ring on my 88 Paso 750. I was directed to do so by my local dealer. Originally I was going to use an X-Ring but was unable to find any at a reasonable cost/quantity. I used a Viton O-ring to replace the bad one. I cleaned up the piston and cylinder with steel wool prior to reassembly. An easy enough job thanks to the dry clutch. One note: I used a Mighty Vac to bleed the assembly after replacement. It worked fast and would be the only way I would suggest doing it.
I can't speak to miles ridden since replacement, my bike has been sitting on stand since, waiting with bad chain. I hope my chainbreaker / rivet tool shows up soon.
Good luck.
Chris
_________________ 1978 Yamaha 650 Special 1987 Yamaha FZ600 1993 Suzuki GSX-R 1100 1995 Kawasaki Ninja 250R (wife's) 1988 Ducati Paso 750 2009 Yamaha FZ1
Top |
fasterdammit
Post subject: Re: What am I getting into here, w/ the clutch ... leak? O-ring? Posted: Sun May 30, 2010 2:31 pm |
Ok, upon closer inspection, the issue doesn't appear to revolve around the clutch, instead it looks like it might be a seal around what looks like a neutral sensor switch or something (guessing; still haven't looked into the book). Definitely not easy to get to. Sound familiar to anyone?
1997 Monster 750
Top |
fasterdammit
Post subject: Re: What am I getting into here, w/ the clutch ... leak? O-ring? Posted: Wed Jun 02, 2010 1:52 am |
1997 Monster 750
Top |
Fraser
Post subject: Re: What am I getting into here, w/ the clutch ... leak? O-ring? Posted: Wed Jun 02, 2010 8:55 pm |
Joined: Tue Jan 17, 2006 12:00 am Posts: 332 Location: Lower Hutt, New Zealand
Hey Faster,
I used a long box spanner. It was out of a really cheap blister pack that had about 6 long box spanners, think it cost $9.00. Terrible quality and I've never used it for anything else, but worked just fine.
Fraser.
_________________ 750 Paso 1980 Moto Morini 500 Sport 2013 Yamaha MT-01
Top |
fasterdammit
Post subject: Re: What am I getting into here, w/ the clutch ... leak? O-ring? Posted: Thu Jun 03, 2010 12:55 pm |
1997 Monster 750
Top |
[ 9 posts ] |
Users browsing this forum: No registered users and 0 guests |
