ducatipaso.org • View topic - little modification for better staring and cranking power
It is currently Wed Jun 17, 2026 10:26 pm
 Post subject: little modification for better staring and cranking power
PostPosted: Mon Sep 26, 2005 4:38 am
PostPosted: Mon Sep 26, 2005 5:38 am
Redpaso
PostPosted: Mon Sep 26, 2005 7:21 am
PostPosted: Thu Sep 29, 2005 7:04 am
:cool: GM Holden use a two way relay to disconnect the A/C on start up the same way as your doing with the headlights. i changed the headlight wiring for bigger cables from the battery via fuses and just use the handlegrip controls to operate relays, this seems too make the headlight a fair bit brighter as well .
PostPosted: Fri Sep 30, 2005 4:51 am
That is even better. You can make such relay combination with two bosch relays. In U.S. it is illegal to have on/off switch for the headlights and they must turn on with your ignition switch on. I noticed that my headlight is a little dim so I will do what you said. :thumbup:
