It is currently Tue Jun 16, 2026 10:18 pm
[ 4 posts ] |
ahdoman
Post subject: Re: Clutch plate sets 750 Paso Posted: Mon Jul 09, 2012 8:03 pm |
Joined: Sat Mar 19, 2005 12:00 am Posts: 107 Location: Santa Clarita, Ca.
Zedder - I recently replaced my clutch with parts I bought from an eBay listing from a guy here in the states. But, I had trouble finding any real clear info on the clutch assembly order and plate specs. Luckily the guy I bought my parts from raced and he knew his stuff. Make sure you have the first plate in as steel then alternate the plates. Also, and this is really important, make sure you have a 5 - 6mm clearance between the outer circlip and the clutch plate. If the clearance is too big it will slip, if it's too small it will stick in gear and make it really hard to find neutral. Because some of my plates were different thicknesses it took me a little bit of work to get the pack correct and have the correct clearance against the big circlip.
_________________ 1988 Red Ducati Paso 750 1999 BMW R1100S
| Top |
ahdoman
Post subject: Re: Clutch plate sets 750 Paso Posted: Tue Jul 10, 2012 3:11 pm |
Being in America I'm not sure of what the conversion rate is but the person that I bought my used clutch pack from also offered me a new one including the metal plates (which the one you show does not include) for $150 usd.
(Note: this info may be wrong but I have no reason not to believe what I have been told) I was told not to necessarily look at the thickness of each plate but the overall tolerances when the pack is assembled. If you have the proper clearance at the circlip and the right number of plates (composite and metal) then your clutch should still work. The really critical issue with each composite plate is that there is still material on it and the critical issue with the metal plates is that they are not heavily damaged (scored, warped, etc.). I think the spec calls out for each plate to be at a minimum thickness of .129in; some of my plates are less than that (.118). In fact, when I put the clutch back together I originally made sure that I used all plates that were at least .129 but it made the pack too thick and it made it really hard to find neutral and the shifting was "tight" not smooth. I swapped out discs so that I had the correct gap to the circlip and all is good. (FYI - My plates vary from .118 to .125).
My point is that you may not need a new clutch pack. If you've managed to salvage units from both bikes you may be good. Or, like I did, purchase a bunch of used plates from eBay. The guy I bought mine from said that some of the Guzzi's use the same plate type.
| Top |
[ 4 posts ] |
Users browsing this forum: No registered users and 24 guests |
