ducatipaso.org • View topic - öhlins overhaul; anyone?
It is currently Mon Sep 29, 2025 4:06 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: öhlins overhaul; anyone?
PostPosted: Fri Aug 17, 2012 7:42 pm
Ok, got the new parts, see plastic bags:
First I had to find a way to take the preload adjuster apart. Couldn't get the piston out. Solved the problem with a little piece of aluminium, see above on the left. Picture down installed:
Fitted new filter oil:
Made an alu block to clamp the axle. Heated the end eye bracket and managed to take it off (just turn it ccw):
Next the adjuster wheel that needs to be replaced. Again managed to take it off, but with a little surprise.. The ring behind the rubber adjuster wheel is damaged. Part is allready en route :cool:
PostPosted: Sun Aug 19, 2012 9:27 am
Hi Brutus,
Great photos! Thanks for posting them :)
Regards,
Mick
906 Paso 1989 w/ 17in wheels :)
PostPosted: Sun Aug 19, 2012 6:27 pm
PostPosted: Sun Aug 19, 2012 9:26 pm
Just out of curiosity Brutus, are the part numbers matching up with the spec sheet I posted ?
Looks like you're doing a great job,it will all go back together a lot easier than it came apart. :thumbup: J.
PostPosted: Tue Aug 21, 2012 7:12 pm
Jay, I've scanned the note and the specsheet that the dealer supplied.
The specsheet is rather of poor quality. Send me a pm if you want a pdf-file. Checked with the specs you've posted and they match:
SPECIFICATION CARD SINGLE SHOCK
Code No. DU5082 replaces DU5081
DUCATI 750 PASO 86-88
Total Length 365 mm , Stroke 78 mm
Head 570-05 , Body 1010-07 , Shaft 1002-02, End Eye 1054-03
Internal Spacers 1069-04,-05 , Shaft Jet 1021-03, Adjustment Valve 1055-03
Valve Stop 519-02 , Piston 514-11 , Adjustment Shaft 566-52
Shims :
Compression.....................Rebound
525-38 ..........................530-34
525-38 ..........................525-30
530-34 ..........................525-26
525-30 ..........................530-23
520-26 ..........................525-21
525-23 ..........................525-19
525-20 ..........................530-18
525-19 ..........................578-01 (2 X)
Spring 1099-05 , Preload 25 mm , Spacer and eye 1018-09 , (Spacer and eye 1018-09)
Hydraulic pre-load adjust 1042-04 , Spring Clip 629-01 , Bump rubber 564-01
Gas Valve 603-01
Piston position 35 mm , Rebound Click 18 , Gas pressure 20 bar
Léon
PostPosted: Tue Aug 21, 2012 9:29 pm
Brutus,Thats good that they match up.It means the information is most likely correct and up to date,for any of the other ohlins paso riders that need it. J.
PostPosted: Sun Aug 26, 2012 8:57 am
Job done! Picked up the spring. Got some loctite 2701 and put it all together again. :lol:
Users browsing this forum: No registered users and 84 guests
