It is currently Mon Oct 26, 2026 4:51 pm
| Author |
ducinthebay
Post subject: Re: Alternatives to stock coils for Digiplex system Posted: Tue Feb 05, 2013 3:00 pm |
| paso grand pooh-bah |
This a nice long string just to get back to the beginning and put on some Dyna Coils, or some SS/Monster coils from the 90's.
Good stuff.
| Top |
ahdoman
Post subject: Re: Alternatives to stock coils for Digiplex system Posted: Fri Feb 08, 2013 2:10 am |
Joined: Sat Mar 19, 2005 12:00 am Posts: 107 Location: Santa Clarita, Ca.
Another question; I got the new (used) coils today and installed them. Does it matter which side of the coil the red wire goes to? The manual shows red to the + side but the coils have no indicators. Just the numbers 15 & 1 on the tops.
_________________ 1988 Red Ducati Paso 750 1999 BMW R1100S
| Top |
Post subject: Re: Alternatives to stock coils for Digiplex system Posted: Fri Feb 08, 2013 3:10 am |
in standard numbering 15 represents the high side 1 is the low side in plain language 1 would be the negative side ( low potential ) 15 is the positive side ( high potential )
| Top |
streetsurfer
Post subject: Re: Alternatives to stock coils for Digiplex system Posted: Sat Feb 09, 2013 4:35 am |
Joined: Sun Jul 30, 2006 12:00 am Posts: 217 Location: Chicago-NW Suburb
Also see that you have near full voltage going to the coils. If there is a significant parasitic loss it may be in your off/run/off or start switch. They can be fairly easily removed, disassembled, and contacts cleaned. While stronger coils helped a missing cylinder condition on my 88, it crept back in as the switch contacts continued to corrode over time. Cleaning them resolved the issue for good by getting full voltage back to the coils.
| Top |
Post subject: Re: Alternatives to stock coils for Digiplex system Posted: Sat Feb 09, 2013 10:20 am |
The best is you put a relay before the coils which connects directly to the battery and is activated by the ignition switch. Not only will this eliminate the voltage loss permanently but you`ll have less current passing the ignition switch which will extend its life.
| Top |
Post subject: Re: Alternatives to stock coils for Digiplex system Posted: Sat Feb 09, 2013 1:06 pm |
Dont forget to fuse the main relay connection to the battery, could save you a rather embarrasing situation down the road
| Top |
bobst2
Post subject: Re: Alternatives to stock coils for Digiplex system Posted: Tue Mar 05, 2013 12:58 pm |
Joined: Sun Jul 24, 2011 1:57 pm Posts: 192 Location: delta b.c. canada
i hope the used coils helped you out. but why go used or do a bunch of mods,to be able to use diffrent coils when new stock coils are avail, from italspares for 40 bucks each.
| Top |
Post subject: Re: Alternatives to stock coils for Digiplex system Posted: Tue Mar 05, 2013 11:04 pm |
This coil primary resistance is something that has always bugged me . When I 1st got my Paso it came with all the usual electrical problems . I was told by the bike shop I got it off not to start it with the lights on, and as ( a very short amount of ) time went by switching the lights on caused backfires and soon it would do it ( backfire ) in time with the blinkers . I later met the previous owner who smugly asked if it was " going OK" ( by which time I had fixed it ) pissed him off no end as he had spent a small fortune trying to fix and that was the reason he sold the bike , he was a wanker so that made it all the better for me . Anyhow whilst " diagnosing" the problem I measured the primary resistance of the coils and noted that they were both 0.4 ohm (less than 1/2 an ohm ) which I thought at the time was lower than I expected, but sinse fixing the electrical issues ( 6 years ago ) this thing has never missed a beat and the coils are still 0.4 ohm ( just measured them again ) . There has obviously been work done to the digiplex module , dunno what . This thing has done some long trips , tank fulls at a time , like plenty of time for whatever to get hot. How come my bike can run 1/2 ohm coils with no ill effect. I am reluctant to think that the coils are crook as they are both the same . Im all for fitting some new , perhaps more powerful coils and will probly do so before it gets put back into regular use ( I need to get myself back into regular use 1st ) MMMMMMMMM ?
beats the crap outa me ( again )
| Top |
Post subject: Re: Alternatives to stock coils for Digiplex system Posted: Wed Mar 06, 2013 9:04 am |
I`ve asked before if the Dyna coils are really the same impedance as the ones for a Digiplex system. Now for the first time checking the 906 manual after Hamish`s post shows it`s not so. It says in chapter M.15 "Coil A.T. circuit resistance: 3700 ohms +/-10%, coil B.T. circuit resistance: 0,34 ohms +/-10%".
| Top |
Users browsing this forum: No registered users and 7 guests |
