ducatipaso.org • View topic - Side stand switch
It is currently Sun Jun 21, 2026 8:44 am
 Post subject: Side stand switch
PostPosted: Sun May 12, 2019 9:44 pm
year: 1985
Hi
How do I remove it? It’s a single wire type. (I have removed the sidestand already)
 Post subject: Re: Side stand switch
PostPosted: Mon May 13, 2019 8:14 am
Unless it's different from the 907 switch, loosen the lock nut then it just unscrews.
PostPosted: Mon May 13, 2019 11:12 am
year: 1985
Thanks... I’ve asked the question badly, I want to discard the switch. Do I earth the wire?
I don’t want any form of cut out. The side stand is removed.
Alistair
PostPosted: Mon May 13, 2019 12:55 pm
If you earth the wire the light in the dash will light up. If you don't want it lit leave the wire disconnected.
PostPosted: Mon May 13, 2019 4:45 pm
year: 1985
Thanks! Will get by without the light.
