ducatipaso.org • View topic - Strange Clutch Problems
It is currently Sat Feb 28, 2026 2:48 pm
 Post subject: Strange Clutch Problems
PostPosted: Sat Apr 15, 2006 3:39 pm
PostPosted: Sat Apr 15, 2006 5:32 pm
PostPosted: Sun Apr 16, 2006 10:01 am
PostPosted: Sun Apr 16, 2006 5:24 pm
PostPosted: Tue Apr 18, 2006 2:51 pm
PostPosted: Tue Apr 18, 2006 8:34 pm
 Post subject: How to insert plates
PostPosted: Thu Apr 20, 2006 8:54 am
Just a other little question: Does it matter in which position I mount the metal plates? They have little marks on the outside, do they have to be in one row?
Felix
PostPosted: Thu Apr 20, 2006 12:33 pm
They definitely do
If you do a search on here or on the yahho group you will find Gerhards guid to clutch packing that he explained a couple of years ago
( I think it was Gerhard apologies to whoever it was if I have mis credited it!)
PostPosted: Fri Apr 21, 2006 5:54 pm
The info is in the 750 tech FAQ at the top of the forum list.
PostPosted: Sun Apr 30, 2006 1:38 pm
I've just posted a reply to another clutch question on the forum and I think it might be appropriate to your problem too:
"I had similar problems with our clutch but eventually tracked down the correct clutch plate fitting sequence which solved the problem. I posted a link about it:
http://forums.ducatipaso.org/viewtopic.php?name= ... highlight="
Hope this helps,
Regards, Steve.
 Post subject: Clutch Problem solved
PostPosted: Fri May 12, 2006 5:26 am
 Post subject: Re: Strange Clutch Problems
PostPosted: Fri May 12, 2006 12:42 pm
