| Strange Clutch Problems http://ducatipaso.org/forum/viewtopic.php?f=1&t=1016 |
| Author: | 68k [ Sat Apr 15, 2006 3:39 pm ] |
| Post subject: | Strange Clutch Problems |
| Author: | Finnpaso [ Sat Apr 15, 2006 5:32 pm ] |
| Post subject: | |
| Author: | 68k [ Sun Apr 16, 2006 10:01 am ] |
| Post subject: | |
| Author: | Finnpaso [ Sun Apr 16, 2006 5:24 pm ] |
| Post subject: | |
| Author: | 68k [ Tue Apr 18, 2006 2:51 pm ] |
| Post subject: | |
| Author: | Finnpaso [ Tue Apr 18, 2006 8:34 pm ] |
| Post subject: | |
| Author: | 68k [ Thu Apr 20, 2006 8:54 am ] |
| Post subject: | How to insert plates |
Just a other little question: Does it matter in which position I mount the metal plates? They have little marks on the outside, do they have to be in one row? Cheers, Felix |
| Author: | Duc750 [ Thu Apr 20, 2006 12:33 pm ] |
| Post subject: | |
They definitely do If you do a search on here or on the yahho group you will find Gerhards guid to clutch packing that he explained a couple of years ago ( I think it was Gerhard apologies to whoever it was if I have mis credited it!) |
| Author: | jcslocum [ Fri Apr 21, 2006 5:54 pm ] |
| Post subject: | |
The info is in the 750 tech FAQ at the top of the forum list. |
| Author: | speedtrifle [ Sun Apr 30, 2006 1:38 pm ] |
| Post subject: | |
I've just posted a reply to another clutch question on the forum and I think it might be appropriate to your problem too: "I had similar problems with our clutch but eventually tracked down the correct clutch plate fitting sequence which solved the problem. I posted a link about it: http://forums.ducatipaso.org/viewtopic.php?name= ... highlight=" Hope this helps, Regards, Steve. |
| Author: | 68k [ Fri May 12, 2006 5:26 am ] |
| Post subject: | Clutch Problem solved |
| Author: | desmodave [ Fri May 12, 2006 12:42 pm ] |
| Post subject: | Re: Strange Clutch Problems |
