It is currently Thu Oct 02, 2025 9:18 am
[ 3 posts ] |
Author |
Rlhanson
Post subject: wiring Posted: Sat Apr 24, 2010 6:56 pm |
basket case paso installed wiring harness but have no spark when turning over. plugs spark when ignition key is turned on both at same time. just once every time key is turned on. wiring not right ?, failed components? every thing else seems to work.
Top |
Post subject: Re: wiring Posted: Sun Apr 25, 2010 4:09 am |
paso grand pooh-bah |
sounds to me like you have power to the coils but not to the ECU ,or a fault in the sensor circut . I think that the 750's had a koukusan ignition which was essentially one seperate unit for each pot , and it is unlikely that both units have packed it in at the same time , much more likely to be something both units have in common , like the power supply or the earth
Top |
persempre907
Post subject: Re: wiring Posted: Sun Apr 25, 2010 8:03 am |
Joined: Tue Dec 06, 2005 12:00 am Posts: 3312 Location: Roma, Italia
Check the RPM sensor on the flywheel. I had it broken and the bike used to stop with no spark. Ciao
_________________ Francesco Ducati 907IE 1992 Rosso Ducati 907IE 1993 Nero Moto Guzzi Galletto 1960 Sabbia BMW R Nine t 2019
Top |
[ 3 posts ] |
Users browsing this forum: No registered users and 83 guests |
