| carburetors out of whack, 750 paso http://ducatipaso.org/forum/viewtopic.php?f=1&t=1116 |
| Author: | shedivy [ Wed May 31, 2006 4:33 pm ] |
| Post subject: | carburetors out of whack, 750 paso |
| Author: | Duc750 [ Wed May 31, 2006 8:31 pm ] |
| Post subject: | |
| Author: | 750pheonix [ Wed May 31, 2006 8:47 pm ] |
| Post subject: | Re: carburetors out of whack, 750 paso |
| Author: | ducapaso [ Wed May 31, 2006 9:45 pm ] |
| Post subject: | |
| Author: | shedivy [ Thu Jun 01, 2006 1:01 pm ] |
| Post subject: | |
| Author: | 750pheonix [ Thu Jun 01, 2006 1:04 pm ] |
| Post subject: | |
| Author: | fasterdammit [ Thu Jun 01, 2006 1:33 pm ] |
| Post subject: | |
No kidding ... FCR's ain't cheap. If you want to work on tuning the Weber some, send a PM to jfiore - he has a great write-up detailing his experiences with the Weber. He's worked his into shape, and has the recipe for anyone else to follow. There's a handful of links in the about it, too |
| Author: | paso750 [ Thu Jun 01, 2006 6:23 pm ] |
| Post subject: | |
here`s some more info about Webers from David Harvey`s old site http://www.geocities.com/750paso/paso/906carb.htm http://www.geocities.com/750paso/paso/906carb2.htm and from Baukes http://www.geocities.com/750paso/paso/weber.html http://www.geocities.com/750paso/paso/f ... blues.html don`t change to FCRs if you aren`t after a performance boost. But also if you are this modification should come with others. Therefore the stock Mikuni from a Supersport/Monster is the better and cheaper choice if you just want a reliable carb. However, the Weber can work nicely it just needs some more attention. Hope the links help. G. |
| Author: | desmodave [ Fri Jun 02, 2006 10:17 am ] |
| Author: | redpaso [ Mon Jun 05, 2006 1:45 am ] |
| Post subject: | |
