It is currently Thu Jun 18, 2026 5:48 pm
[ 4 posts ] |
| Author |
Christian
Post subject: Oil cooling and motor temperature Posted: Mon Aug 09, 2004 5:58 am |
Joined: Thu Jul 15, 2004 12:00 am Posts: 29 Location: Fribourg, Switzerland
The temperature level is very long time to increase up to 50°C.
Depending on the ambiant temperature, the level coms never up to 50°C. it's not enough for a right using motor.
Do you have experience ? What's the solution ?
The oil must cross the radiators to garanty a good lubrification or is it possible to stop the oil before radiator with a termostat ?
Thanks for help
Christian
| Top |
v2block
Post subject: Posted: Fri Aug 13, 2004 3:58 pm |
helo christian, i would stop the airflow in the radiators .close them with a strong tape like duc-tape or similar. but keep an eye onthe temp..
| Top |
lceriani
Post subject: Posted: Mon Aug 16, 2004 9:56 pm |
Joined: Mon Jul 19, 2004 12:00 am Posts: 163 Location: Saronno (Varese), Italy
50°C seems too low... I usually go up to 80-100°C on summer.
Is the temperature sensor ok? Are the connector oxidated?
LC
| Top |
ducapaso
Post subject: Posted: Sat Dec 25, 2004 9:52 pm |
| paso grand pooh-bah |
Joined: Sun Aug 01, 2004 12:00 am Posts: 1097 Location: siena, italy
I have your same trouble on my dukess...
The engine is running good, however I'm in order to ceck the valve located between the pump and the oil filter... I suppose it should bypass the oil flow straight to the engine in case of troubles in the coolers.... I think I'll clean the coolers inside too, so I'll be able to tell you something about.
Have a nice ride, Ducapaso
| Top |
[ 4 posts ] |
Users browsing this forum: No registered users and 30 guests |
