| Dellorto blowback http://ducatipaso.org/forum/viewtopic.php?f=1&t=118 |
| Author: | minimad [ Fri Nov 26, 2004 11:07 pm ] |
| Post subject: | Dellorto blowback |
Try this on for size. i get blowback through the horizontall cylinder carburettor, when bike has warmed up. changed the coils, reguiator,battery and spark plugs. |
| Author: | Skins [ Sat Nov 27, 2004 9:10 am ] |
| Post subject: | |
:confused: This sounds a bit strange, minimad. If you're having trouble on just one cylinder, why change the regulator and battery? If the trouble is spark, how come it only happens when the motor's warm? How about checking out the front carburetor? Does it blow back under acceleration, or at idle? Maybe the front carb is rich, so it runs OK only when cold. |
| Author: | minimad [ Sat Nov 27, 2004 10:15 pm ] |
| Post subject: | |
Idie or acceleration it dos't change,and ouly when warmed (about 20mins after startup). changed jet size to bigger one, still didn't change. |
| Author: | Skins [ Sun Nov 28, 2004 2:22 am ] |
| Post subject: | |
How well are your carbs synchronized, are you using reccomended plugs, and does the front plug look rich or lean? |
| Author: | minimad [ Sun Nov 28, 2004 3:06 am ] |
| Post subject: | |
yes and yes. it's carbon fouling both spark plugs, with both bigger jets and small jets. it's like the motor start to run on one cylinder, and starts to fire at uneven times. can't reuse spark plugs again, even after cleanup. (motor won't start) |
| Author: | Skins [ Sun Nov 28, 2004 3:50 am ] |
| Post subject: | |
So you're having trouble with both cylinders? |
| Author: | jcslocum [ Sun Nov 28, 2004 1:45 pm ] |
| Post subject: | Re: Dellorto blowback |
| Author: | minimad [ Tue Nov 30, 2004 4:59 am ] |
| Post subject: | |
| Author: | Skins [ Tue Nov 30, 2004 6:31 am ] |
| Post subject: | |
| Author: | jomo [ Tue Dec 21, 2004 10:49 am ] |
| Post subject: | |
| Author: | minimad [ Mon Dec 27, 2004 1:29 am ] |
| Post subject: | |
| Author: | steele [ Mon Dec 27, 2004 9:31 am ] |
| Post subject: | |
I would agree with jomo on this one look for airleaks |
