| What spark plugs are best? http://ducatipaso.org/forum/viewtopic.php?f=1&t=1191 |
| Author: | Marinus [ Mon Jul 10, 2006 11:44 pm ] |
| Post subject: | What spark plugs are best? |
What spark plugs are people useing? I took mine out and found that there were NGK's in it but they were no even the same as each other. The manual has Champion RA6YC in it. |
| Author: | jcslocum [ Tue Jul 11, 2006 12:03 am ] |
| Post subject: | |
NGK's are good spark plugs. |
| Author: | Marinus [ Tue Jul 11, 2006 2:21 am ] |
| Post subject: | |
Hi Jon While the bike is apart I was looking at doing the wiring upgrade. When I look at the photos of your bike it almost looks like a different bike. My bike is very original and although first registerd in 1990 I would say it was made late in 88. My Rgulator is on the right hand side of the bike. I have a large ignition box where your regulator is different rear suspention, carbs, cans and different coils. not a problem just interesting how different two bikes can be. Have you put a relay on the headlight? |
| Author: | persempre907 [ Tue Jul 11, 2006 6:18 am ] |
| Post subject: | |
All the spark plugs are quite similar. The most important thing is the clearance, rather than the brand. Ciao |
| Author: | paso750 [ Tue Jul 11, 2006 9:12 am ] |
| Post subject: | |
Well, when my Paso was still completely original it came with Nippon Denso plugs. The bike of course was back-firing occasionally and when I changed them to NGK and then to NGK Iridium plugs things became even worse. Since then I`m using Champion RA6HC plugs and am very happy with them. I don`t say the other plugs are bad as with a good setup of ignition and engine they may have worked fine, but Champions were never so picky. The RA6HC replaced the RA6YC longer time ago. Gerhard |
| Author: | Marinus [ Tue Jul 11, 2006 11:20 am ] |
| Post subject: | |
Thanks. I just bought the Champions RA6HC's They are 1/4 of the price of the NGK Iridium plugs and they had them in stock. Sometimes 4 times the price is not mean it's better for every aplication. |
| Author: | jcslocum [ Tue Jul 11, 2006 12:51 pm ] |
| Post subject: | |
| Author: | KillerB [ Thu Jul 13, 2006 8:45 pm ] |
| Post subject: | |
| Author: | ducinthebay [ Mon Aug 07, 2006 2:38 am ] |
| Post subject: | Champion plugs |
I switched to the Champion plugs and the bike ran much better than with NGK plugs. And yes, they are cheap, when you find them. I went to 4 different Autopart stores to find them. When the guy told me that they were only $1.50ea, I just took 4 and put the spare pair in the tool kit. Phil |
