Speedometer http://ducatipaso.org/forum/viewtopic.php?f=1&t=1233 |
Author: | pompone [ Sat Aug 05, 2006 1:43 am ] |
Post subject: | Speedometer |
Author: | jcslocum [ Sat Aug 05, 2006 1:54 am ] |
Post subject: | |
Author: | delagem [ Sun Aug 06, 2006 12:26 am ] |
Post subject: | |
I would contact some race shops, most racers take the speedo drive off and substitute an aluminum spacer, somebody must have a stack of them somewhere! |
Author: | ducapaso [ Sun Aug 06, 2006 7:08 am ] |
Post subject: | |
You mean this? http://it.msnusers.com/pasochisti/shoeb ... &PhotoID=9 There's a ratio number punched in the body, mine is 21/12 and refers to the gear inside it. I happened the same thing and I went searching to an "used spare parts fair" (is there a sigle word for this?) You must take care not to find a left spinning speedo, even if a similar ratio (such as 19/11) will do |
Author: | paso750 [ Mon Aug 07, 2006 1:48 pm ] |
Post subject: | |
the speedo angledrive of the Aprilia RS125 was mentioned once on the mailing list. I wonder if that is correct though as I think the 125 has 17" wheels, doesn`t it ? G. |
Author: | pompone [ Mon Aug 07, 2006 11:16 pm ] |
Post subject: | |
Thank you. I'll go to an Aprilia dealer with my broken speedometer. I'll remeber the ratio, Ducapaso. :thumbup: Paso 750, Aprilia RS 125 has a 110/17 tire, maybe it is aproximately like 130/60-16 perimeter. I use in my Paso 130/70-16. |
