ducatipaso.org • View topic - Fuel flow restriction?
It is currently Sun Sep 28, 2025 11:48 pm
 Post subject: Fuel flow restriction?
PostPosted: Sun Aug 20, 2006 9:09 pm
Nick
'74 R75/6
'88 750 Paso
'04 R1150RT
PostPosted: Mon Aug 21, 2006 11:08 am
Nick,
your return rubber pipe is it connected to the good pipe of the tank? One of these pipes is blind...
PostPosted: Mon Aug 21, 2006 8:16 pm
I use the rear pipeconnection. No problem with overflow yet!
PostPosted: Tue Aug 22, 2006 3:50 am
I have mine connected to the rear pipe as well. I just don't understand why nobody else has had this problem. I am seriously debating just putting the old weber back on and forget this stupid mikuni conversion all together. I have not ridden the bike this year!
Nick
'74 R75/6
'88 750 Paso
'04 R1150RT
PostPosted: Tue Aug 22, 2006 9:09 am
how is connected your Y? the pump is it connected on its "foot"?
PostPosted: Tue Aug 22, 2006 3:00 pm
The way I have it plumbed now is: the fuel line comes out of the fuel tap, goes to a filter, then the pump, then about four or five inches of hose and then it y's off, one leg goes about a half inch then is connected to a fuel pressure regulator, then another half inch then it goes to the fuel inlet of the carbs, the other leg of the y goes to the rear spigot of the tank.
Nick
'74 R75/6
'88 750 Paso
'04 R1150RT
PostPosted: Tue Aug 22, 2006 3:59 pm
PostPosted: Tue Aug 22, 2006 4:06 pm
PostPosted: Tue Aug 22, 2006 4:37 pm
Nick
'74 R75/6
'88 750 Paso
'04 R1150RT
PostPosted: Tue Aug 22, 2006 6:46 pm
PostPosted: Tue Aug 22, 2006 8:37 pm
I don't really understand how exactly to connect this clear rubber hose you speak of?
Nick
'74 R75/6
'88 750 Paso
'04 R1150RT
PostPosted: Wed Aug 23, 2006 8:19 am
PostPosted: Wed Aug 23, 2006 8:56 am
PostPosted: Wed Aug 23, 2006 8:41 pm
PostPosted: Sat Aug 26, 2006 8:11 am
