ducatipaso.org • View topic - centerstand, clutch, carburator kit
It is currently Fri Mar 06, 2026 9:58 pm
 Post subject: centerstand, clutch, carburator kit
PostPosted: Tue Oct 17, 2006 7:28 pm
Guys,
I'm dickering for an 88 Paso that needs these three items: a centerstand (missing), a clutch job (very, very grabby), and probably a carburator cleaning with a new kit installed. The tool kit is also missing. How much money, ballpark, am I looking at for these items. Since I beleived the seller when he said the bike was perfect, I told him that $2,850 was an agreeable price. After riding it, I'm not so sure. Any thoughts?
Thanks for your comments.
PostPosted: Tue Oct 17, 2006 8:43 pm
Hi Ricardo,
the center stand is very cheap, you could try on eBay and I think you will pay it not more than 20 $.
I've not understood about the clutch job, can you explain to me?
The carburator servicing is not much expensive, but if you want to replace it with a couple of Mikuni or Dellorto :lick: you will pay 2-300 $., if used, and over 1000 $. for a new one.
The tool kit don't have a good quality, so I wouldn't cry about it, but the price (2850 $.) seems to me a little bit expensive if the bike is not perfect and don't has a low mileage.
Let us know.
PostPosted: Tue Oct 17, 2006 10:43 pm
The clutch pack (if that's what it needs) will be about $125 for the parts plus labor. The carb really isn't worth rebuilding if it's the weber so as has been mentioned a move to Mikuni's or Dellorto's is a wise move.
Depending on mileage and condition $2K would be whatr I would think about paying.
Other things to be considering:
Timing Belts
Tires
Valve Adjustment
These will likely also need to be done.
