| Top End mods? http://ducatipaso.org/forum/viewtopic.php?f=1&t=1317 |
| Author: | ducinthebay [ Sat Sep 16, 2006 4:52 am ] |
| Post subject: | Top End mods? |
What are some of the common head modifications and /or piston mods for the 750 motor. Mine is starting to act a bit tired, and if I'm going to go into it, I may as well hop it up a bit while I got it apart. The Paso/Sport motor was the first of the new motor series that carries on still. What parts can be adapted for more performance? Now I've heard that the 900SS cams work nicely in the 750 motor, and that the ST2 cams work real nice in 900SS motors. Would ST2 cams work dandy in the 750 motor? Are there other Ducati pistons that work well in this motor that are higher compression, or lighter, or just a bit bigger? The Sport came with 10:1 pistons. Lager valves? Rocker arms? How much of the SS/Monster/ST stuff will fit? Should I just get some newer heads and drop them on? Like a need another project....:umm: |
| Author: | ducapaso [ Sun Sep 17, 2006 6:56 am ] |
| Post subject: | |
You can make a search for "big bore" 780 cc pistons... In itay they're available for about 1000€. I heard nothing about cams, except of ducati performance |
