| clutch airleak? http://ducatipaso.org/forum/viewtopic.php?f=1&t=1329 |
| Author: | pikey [ Thu Sep 21, 2006 12:21 am ] |
| Post subject: | clutch airleak? |
well, about a week ago I noticed that the clutch was begining to drag a little bit, but by the time I reached my destination, I had no clutch at all. so I took the cover off and checked the plates/piston/bearing, and all seemed well. so I decided to try and bleed the clutch and sure enough there was a good bit of air in the line. after that the clutch worked fine for about a day. and then it began dragging again. same problem. all the crush washers are there and everything seems in order. now the question is how do I isolate such a slight leak? should I just say the heck with it and rebuild from master to slave? any help would be most appreciated! ............pikey |
| Author: | nilaus [ Thu Sep 21, 2006 7:15 am ] |
| Post subject: | Hi! |
Is there any external leakage or is it all internal? Regards Klaus PASO 750, 1990 |
| Author: | Rodney [ Thu Sep 21, 2006 8:11 am ] |
| Post subject: | |
:confused: does the fluid disappear as well or does it just suck in air it sounds like the o-ring in the clutch slave bearing is shot you may have to replace this or the whole bearing itself . Rodney |
| Author: | jcslocum [ Thu Sep 21, 2006 11:01 am ] |
| Post subject: | |
| Author: | pikey [ Thu Sep 21, 2006 9:31 pm ] |
| Post subject: | |
| Author: | Rodney [ Sat Sep 23, 2006 12:10 pm ] |
| Post subject: | |
| Author: | yellerduck [ Sun Sep 24, 2006 1:22 am ] |
| Post subject: | |
| Author: | Rodney [ Sun Sep 24, 2006 1:06 pm ] |
| Post subject: | |
| Author: | pikey [ Mon Sep 25, 2006 9:03 pm ] |
| Post subject: | |
| Author: | ducinthebay [ Tue Sep 26, 2006 5:14 am ] |
| Post subject: | Air in the system |
| Author: | BellaPaso [ Tue Sep 26, 2006 1:57 pm ] |
| Post subject: | |
| Author: | pikey [ Wed Sep 27, 2006 9:29 pm ] |
| Post subject: | |
Bellapaso, if I find a resolution I will most certainly let you know! pikey |
| Author: | yellerduck [ Thu Sep 28, 2006 1:42 am ] |
| Post subject: | |
Pikey, I feel your pain. This past weekend, I have spent countless hours trying to get the air out of my clutch line without success. Now I have taken the gloves off and it's me and the clutch. I took my clutch cover off, put two clear lines: one on the inlet goint to a can of brake fluid and one bleed hole. I ran the bleed hole tube through my vacuum pump. Still sucking gobs of air out. I even siliconed the piston area to see if it was leaking there. This is really blowing my mind. I can't seem to get the air out. So far, it's kicking my butt but the fight isn't over. Is there anyone else out there that has conquered this problem? |
| Author: | pikey [ Thu Sep 28, 2006 3:17 am ] |
| Post subject: | |
I have no problems bleeding the clutch, but then again I have never started with the line empty. I'm never really getting much air. the problem seems solved after I bleed the line, but within 20 miles it begins dragging again. I'm getting murderously frustrated with it. I am about to just friggin rebuild the whole damn thing, from top to bottom! pikey |
