| at wit's end with my F@#*ing clutch http://ducatipaso.org/forum/viewtopic.php?f=1&t=1336 |
| Author: | yellerduck [ Sun Sep 24, 2006 1:18 am ] |
| Post subject: | at wit's end with my F@#*ing clutch |
Today, I spent all day literally, trying to get the air out of my clutch line. I have came to the conclusion that there must be some kind of air leak coming in from somewhere. Has anyone had this problem? I don't know what to do I have tried everything I know. very pissed |
| Author: | ducapaso [ Sun Sep 24, 2006 8:24 am ] |
| Post subject: | |
| Author: | yellerduck [ Sun Sep 24, 2006 12:42 pm ] |
| Post subject: | |
| Author: | ducinthebay [ Mon Sep 25, 2006 3:17 am ] |
| Post subject: | get the air out |
| Author: | Marinus [ Mon Sep 25, 2006 4:18 am ] |
| Post subject: | |
| Author: | yellerduck [ Thu Sep 28, 2006 1:38 am ] |
| Post subject: | |
I am familiar with the methods mentioned above but I have taken things a step farther. I took my clutch cover off, put two clear lines: one on the inlet goint to a can of brake fluid and one bleed hole. I ran the bleed hole tube through my vacuum pump. Still sucking gobs of air out. I even siliconed the piston area to see if it was leaking there. This is really blowing my mind. I can't seem to get the air out. Is there anyone out there that has had bad experience getting air out of the clutch line / cover? Is this an impossible feat? |
| Author: | qldman36 [ Thu Sep 28, 2006 2:47 am ] |
| Post subject: | |
Do you have the bleeder screw too loose so that it is sucking air in through the threads? Just a thought. |
| Author: | yellerduck [ Mon Oct 23, 2006 1:01 am ] |
| Post subject: | |
| Author: | jcslocum [ Mon Oct 23, 2006 1:44 am ] |
| Post subject: | |
| Author: | Garnet [ Mon Oct 23, 2006 2:52 am ] |
| Post subject: | |
| Author: | DesmoDog [ Mon Oct 23, 2006 4:17 am ] |
| Post subject: | |
