| STUPID IGNITION PICKUPS! http://ducatipaso.org/forum/viewtopic.php?f=1&t=1376 |
| Author: | pikey [ Tue Oct 10, 2006 5:40 am ] |
| Post subject: | STUPID IGNITION PICKUPS! |
well heres the story: started the paso up the other morning, and had a lot of trouble getting her started. once I got her running, the motor sounded kind of rough, but I was still half asleep and just figured it needed to warm up. As soon as I started rolling I knew something was indeed very wrong. There was NO power at all. I then realized why the motor sounded so strange: She was only running on one cylinder! so I finaly made it to the motorcycle shop I work at. first thing I did was put new plugs in, and checked for spark. sure enough the lower cylinders coil was not sparking. so I swapped plug wires and checked spark, and it appeared that the same coil was stil not firing. so then I swapped the lead wires to the coils and the suspected coil fired. Long story short, I eliminated the possibility that the coils or igniters could be bad, which left the ignition pickup for said cylinder. I test both and the lower cylinders pickup was no good. so its either the wire leading to the pickup or the pickup itself. any suggestions? any body know where I can find a set of pickups? all help is appreciated!!! -pikey |
| Author: | Desmo_Demon [ Tue Oct 10, 2006 1:36 pm ] |
| Post subject: | Re: STUPID IGNITION PICKUPS! |
| Author: | pikey [ Tue Oct 10, 2006 8:14 pm ] |
| Post subject: | |
