It is currently Thu Oct 29, 2026 12:58 am
 Post subject: Workshop manual for PASO 750 with DIGIPLEX (Advance Timings)
PostPosted: Fri Oct 08, 2010 8:56 am
I have been looking for the Paso 750 DIgiplex advance diagrams, but all the versions of the workshoop I find refer only to the KoKusan Modules.
You can get the Digiplex curves on the 906 manual, but I wanted to see what sort of timing curves were used on the 750.
I remember the Digiplex box had a different number on it, they were interchangeable (in fact my P750 had a 906 box on it) but i have the feeling the advance timing was quite different.
 Post subject: Re: Workshop manual for PASO 750 with DIGIPLEX (Advance Timings)
PostPosted: Thu Oct 14, 2010 12:25 am
1987 Paso 750. I have to turn off the petcock when I park the bike or gas leak out the overflow. Does this mean the carb float is stuck? Is there a cure or does the carb need overhauled?
Jeff
