Paso exhaust noise level http://ducatipaso.org/forum/viewtopic.php?f=1&t=1464 |
Author: | Wanderer [ Sat Nov 18, 2006 7:27 pm ] |
Post subject: | Paso exhaust noise level |
Author: | Finnpaso [ Sat Nov 18, 2006 7:48 pm ] |
Post subject: | |
Author: | Wanderer [ Sun Nov 19, 2006 6:48 am ] |
Post subject: | |
Author: | Finnpaso [ Sun Nov 19, 2006 11:45 am ] |
Post subject: | |
Author: | persempre907 [ Sun Nov 19, 2006 3:35 pm ] |
Post subject: | |
Author: | Finnpaso [ Sun Nov 19, 2006 4:11 pm ] |
Post subject: | |
Author: | spaynenda [ Thu Dec 07, 2006 6:31 am ] |
Post subject: | |
Just after purchasing new in 1988, I fitted the pipes & mufflers from the Limited model. After installing a K&N low restriction filter and re-jetting, it ran (and still runs) great, sounded much better, yet is not too loud--quite mellow actually, as I didn't adopt the larger valves of the Limited model. The diameter of pipes and outlets is significantly larger, but keep in mind the mufflers are plainly marked for track use only. The thing I like about them, if you can find a set, is they look stock (except of course for the outlet diameter). [/img] |
