| Foam insert in oil vapor return line http://ducatipaso.org/forum/viewtopic.php?f=1&t=1513 |
| Author: | betenoire [ Wed Dec 20, 2006 5:35 pm ] |
| Post subject: | Foam insert in oil vapor return line |
| Author: | streetsurfer [ Wed Dec 20, 2006 9:20 pm ] |
| Post subject: | |
| Author: | jcslocum [ Thu Dec 21, 2006 10:35 pm ] |
| Post subject: | |
| Author: | Finnpaso [ Fri Dec 22, 2006 3:44 pm ] |
| Post subject: | |
| Author: | lceriani [ Tue Jan 02, 2007 5:58 pm ] |
| Post subject: | |
Also in my Paso the pipe breathes directly into the air. Here in Italy it's illegal because of pollution restrictions, but I had no choice with air filters and no airobox... I placed my pipe on the left side of the bike: Indeed, I don't like all that oil leaking from the pipe to the rear chain/wheel. Did anyone try a better placement? I know that on Monsters someone connects an air filter directly to the valve from engine, but this solution is dangerous because if the filter gets dirty, oil overpressure may occur. A better solution is to place an alluminium can, as in racing bikes. Here is an handmade solution for Monsters: So... what did you do on yuor Paso? LC |
| Author: | Finnpaso [ Tue Jan 02, 2007 7:01 pm ] |
| Post subject: | |
| Author: | wilbur [ Tue Jan 02, 2007 11:44 pm ] |
| Post subject: | |
I've used these in the past. Mounted the stud to the tab where the rear part of the fuel tank mounts. Oil always has a chance to flow back to engine cause it is almost straight up. Not sure what diameter it was but they make it in 3/4" and 1" o.d. pipe :thumbup: It is made for crankcase ventilation. |
| Author: | Christian [ Wed Jan 03, 2007 8:31 pm ] |
| Post subject: | |
| Author: | lceriani [ Wed Jan 03, 2007 11:30 pm ] |
| Post subject: | |
| Author: | wilbur [ Thu Jan 04, 2007 3:24 am ] |
| Post subject: | |
| Author: | Christian [ Thu Jan 04, 2007 7:20 pm ] |
| Post subject: | |
| Author: | lceriani [ Fri Jan 05, 2007 9:56 am ] |
| Post subject: | |
did you remove the black plastic box that originally was connected to the cranckase and to the airbox? (the "mistery box" of ) LC |
| Author: | Christian [ Fri Jan 05, 2007 8:25 pm ] |
| Post subject: | |
Yes, I had remove the black box. I not have the original air box filter, I have a special K&N filter directly mounted on carb to give a maximum air of motor ! |
| Author: | lceriani [ Tue Jan 09, 2007 1:00 pm ] |
| Post subject: | |
