MYSTERY BOX??? http://ducatipaso.org/forum/viewtopic.php?f=1&t=1543 |
Author: | pasophist [ Fri Jan 05, 2007 5:57 am ] |
Post subject: | MYSTERY BOX??? |
Author: | paso750 [ Fri Jan 05, 2007 9:05 am ] |
Post subject: | |
Author: | streetsurfer [ Fri Jan 05, 2007 4:53 pm ] |
Post subject: | |
When I took mine out the bolt and nut had seized. Being that the nut was captured or kind of heat welded into the plastic tank, it required prying the nut/bolt upward and prying the box downward to get them apart. It can now be repaired with a wellnut, if I ever want to return it to use. |
Author: | wilbur [ Fri Jan 05, 2007 5:13 pm ] |
Post subject: | |
Everyone removes this box when they convert to individual carbs like Mikunis or Dellortos. Because there is no longer a way to pipe it into the stock airbox which is no longer used. You can install the little black box back if you wish or you can install a crankcase breather filter directly on the hose from the engine. check out this thread |
Author: | pasophist [ Sun Jan 07, 2007 7:47 pm ] |
Post subject: | Thank you! |
Author: | wilbur [ Mon Jan 08, 2007 2:40 am ] |
Post subject: | |
Look here for some info on body panel fasteners. :thumbup: |
Author: | pasophist [ Mon Jan 08, 2007 4:23 am ] |
Post subject: | Fasteners |
Thanks Tim. I'll look into that. Pasophist |
