POd filter http://ducatipaso.org/forum/viewtopic.php?f=1&t=1545 |
Author: | ducapiero [ Fri Jan 05, 2007 3:02 pm ] |
Post subject: | POd filter |
After the mikuni upgrade i want to buy 2 pod filter,but i don't know the exact measurment that they have to do,i bought two sport filter from an auto tuning shop,but they are too big ![]() i don't lose money but now i have to order two filter in these shop.... Help requred :confused: :confused: :confused: |
Author: | jcslocum [ Fri Jan 05, 2007 4:26 pm ] |
Post subject: | |
I have K&N filters on my Paso but that is with Dellorto carbs. Here is a link to the K&N site with info on these filters. You will have to measure the inlet outer diameter and match them up. http://tinyurl.com/ylabds |
Author: | nilaus [ Fri Jan 05, 2007 5:47 pm ] |
Post subject: | UNI-filtre |
UNI-filtre should be good. I will be mounting a pair these i think. http://www.repairmanual.com/items/70 Regards Klaus |
Author: | Finnpaso [ Fri Jan 05, 2007 6:59 pm ] |
Post subject: | |
Klaus, WHITCH of those modell fits to Mikunis??? I dont have yet Mikunis(maybe soon), only 40mm Dellortos fitted and Webers(in garrage shelves)... But i must think future also... ![]() |
Author: | nilaus [ Fri Jan 05, 2007 7:44 pm ] |
Post subject: | POD 57 mm. |
If you are mounting direct to the mikuni, the 57 mm. will fit. But I am not sure of the clearens inside the tank. I am making a swep above the mikuni some thing like on the picture belowe. http://www.motorcykelgalleri.dk/html/ga ... sp?ID=1846 See last picture. It is not from my PASO but the others are. Regards Klaus |
Author: | Finnpaso [ Fri Jan 05, 2007 8:51 pm ] |
Post subject: | |
So, from WHERE are coming those white air intake manifolds to fit filters? Looks, that it can function well with pod filters and seems, that enough small system to fit under Paso tank... :thumbup: Btw, is It You, Klaus in that one foto sitting in Paso? Not so bad! :thumbup: |
Author: | wilbur [ Fri Jan 05, 2007 9:02 pm ] |
Post subject: | |
sweeps look like PVC plastic piping. 180 degree bends. |
Author: | Fraser [ Fri Jan 05, 2007 10:14 pm ] |
Post subject: | |
Hey there ducapiero, Foam pods work just fine as long as the diameter is correct. I used Unifilter pods for the Mikunis, type PK79, refer to http://www.unifilter.com.au for more details. Fraser. |
Author: | ducapiero [ Sat Jan 06, 2007 1:09 pm ] |
Post subject: | |
thanks a lot guys for all your replies.... i 'll give you soon some development... ![]() |
