| Manuals, magazine articles and other downloads http://ducatipaso.org/forum/viewtopic.php?f=1&t=1551 |
Page 1 of 9 |
| Author: | paso750 [ Sun Jan 07, 2007 3:08 pm ] |
| Post subject: | Manuals, magazine articles and other downloads |
Hi everyone, most of the files below can be found also in the document section of the main site. I`ve uploaded the files on an external hoster, too just in case the site should crash and files get lost as it already happened in the past. I don`t know if the place I`ve uploaded the files has a traffic limitations, if so pls retry another time. Also if the pages don`t show in your browser hit the refresh button. If you own magazine articles, brochures etc and have the possibility to scan them let me know via pm. Note: if you follow one of the links below and then click on the download button you may get a 'register'/'log-in' pop-up. Ignore that. Just wait a second and you'll get a message from your webbrowser asking if you want to open or download the file. Brochures and magazine articles: Magazine articles and reviews General: Ducati Paso buyer`s guide https://app.box.com/s/2fhq2uukm6t3hc14mboele7zupkdgq2e Ducati Belt-Drive Two-Valve Twins - Restoration and Modification (Paso/Sport part & appendix - production numbers/ technical specs - only) Haynes manual SS/Monster (for Paso/Sport relevant parts only) Overview of clutch discs packs & disc order from SURFLEX https://app.box.com/s/w2y6okcblz8ve8xtxr45 https://app.box.com/s/0jou7koxsuy3fd8vwhcmratvm8w0m3yo engine doesn`t start - fault finding chart (doesn`t cover specific 907i.e. issues) https://app.box.com/s/x8fmn1brzuya97x8z44z Service bulletin regarding gear selector mechanism - all Ducati models https://app.box.com/s/ccqi4o1hoelpn458dffawwf51kiq20cs Carburation: Weber manuals Mikuni manuals Dellorto manuals Keihin FCR carb infos/manuals fuel hose specifications https://app.box.com/s/ut9pl8qs48zin0rbwf016cal8vtybvb2 Valve timing: Adjusting valve timing (cam dialling) about valve timing and camshaft specs https://app.box.com/s/pst9p706lhf9nvrf8kzpm6kcr5zefayb timing disc: http://www.bevelheaven.com/downloads/Un ... ngDisc.bmp diy TDC finder Electrics: charging system (stator & regulator/rectifier) fault finding chart from ELECTREX/ElectroSport ElectroSport ESR515 and Electrex RR51 installation Diode testing guide from ElectroSport Shin Yo regulator installation https://app.box.com/s/y5n81gem88ul3ymp6a0v Repairing the ignition switch Repairing the starter solenoid (shown on a Pantah engine) Repairing the starter motor (shown on a Pantah engine) Casting your own front turn signal lenses Suspension & steering: Marzocchi M1R fork manual Marzocchi M1R fork stop rings dimensions Marzocchi DuoShock service manual new rear excenters for 17" conversion (17mm axle from a SS can be used, hence no need to machine the wheels to fit larger bearings) bar risers drawings and CAD files + video Brakes: tutorial on how to convert to 4 piston Brembo brake calipers incl. drawings and CAD files brake adapters and some other info on 17" wheel conversion of P750/906 brake adapters for 17" wheel conversion (calipers with 65mm mounting hole distance) brake adapters for 300/320mm discs on Marzocchi M1R fork (calipers with 40mm mounting hole distance) Brembo P4 caliper dimensions Luggage carrier systems: mounting instructions for NonFango luggage carrier rack for 906 mounting instructions for Givi luggage carrier rack for 750/907ie instructions for Givi universal mounting kit (for Givi wingrack carrier systems) Hepco & Becker luggage rack (german description only) Ducati Paso 750: P750 owner`s manual US version P750 owner`s manual multi language version P750 owner`s manual - California version (w/ Marelli Digiplex ignition) P750 workshop manual P750 parts catalogue P750 wiring diagram (in colour) P750 wiring diagram - California version (w/ Marelli Digiplex ignition) (in colour) P750 wiring modifications P750 Weber 44DCNF-107 and -110 & jetting TÜV Bescheinigungen für Alternativbereifungen (german TÜV approval for alternative tires) Metzeler/Bridgestone Avon Ducati Paso 906: P906 owner`s manual US version P906 workshop manual P906 parts catalogue P906 wiring diagram (in colour) P906 wiring modifications Weber mod and jetting for the P906 coolant reservoir modification TÜV Bescheinigungen für Alternativbereifungen (german TÜV approval for alternative tires) Ducati 907i.e. 907i.e. owner`s manual 907i.e. workshop manual (supplement to the 906 wsm) 907i.e. parts catalogue 907i.e. wiring diagram (in colour) 907i.e. wiring modification coolant reservoir modification swingarm/brake caliper bracket pin - drawing repairing the fuel pump adjusting CO trim adjusting TPS (throttle position sensor) fuel hose specifications https://app.box.com/s/ut9pl8qs48zin0rbwf016cal8vtybvb2 Unbedenklichkeitsbescheinigung für Reifenumrüstungen (german documents of compliance for alternative tires) https://app.box.com/s/2bikt9sc0p1knplq1jrpha3stcp2jbhq left and right swingarm decals (printable pdfs) (these are not for the P750/906 as the necessary chain slack is different!) https://app.box.com/s/oo896rmygkkgl6gzj08cklpdd5uun0wy documenti di omologazione (italian homologation documents) https://app.box.com/s/vxb8chbfpan45ru0q9qqg4b5xr0dygri Ducati 750S: 750 Sport owner`s manual 750 Sport workshop manual 750 Sport parts catalogue 750S wiring diagram in colour 750S wiring modifications TÜV Bescheinigungen für Alternativbereifungen (german TÜV approval for alternative tires) Ducati 900SS '90: 900 Supersport owner`s manual 900 Supersport workshop manual 900 Supersport parts catalogue 900 Supersport specs 900 Supersport frame, swingarm and fork dimensions 900 Supersport wiring diagram (in colour) Miscellaneous : Twist of the wrist 1&2 (pdf books) Reducing advance timing Primary gear locking wrench (diy) Alternator cover puller (diy) Toolkit contents overview Spark plug overview for big bore and HC kits Spark plug heat range crossreference chart Overview of Marelli Digiplex units Öhlins shocks service manuals Öhlins steering damper service manual label showing setup of California bikes / emission control regulation Ducati Paso 750, 906 & 907i.e. Info zur Abgasuntersuchung (info for emissions control, relevant for Germany) desktop background picture Ducati 906 - 1280x1024 Crankcase breather article 2 articles on exhaust systems article on engine oil Italo Shop Neuss '93 Katalog test of Moto Morini 350 Dart (Paso lookalike) Ducati 851 888 manuals Remote oil filler (drawing & pictures) https://app.box.com/s/kohcxdnssrfnyywofb8q4289mqehizfy Ducati 750 900 Supersport manuals ('91-'97) Ducati 750 F1 manuals https://app.box.com/s/wq12jqesd32h5g017za2 Ducati Indiana 350-650 parts catalogue Ducati ST2 manuals Cagiva Alazurra 350-650 manuals Cagiva Elefant manuals Cagiva Freccia 125 C10R C12R manuals Reparaturanleitung Monster 600/750 & 900 ab ´93 (german only) other motorcycle manuals http://www.carlsalter.com/motorcycle-manuals.asp http://www.manualedereparatie.info http://www.pdfmotomanual.com/index.php? ... 8&lang=ENG Ducati Paso videos: have fun G. |
| Author: | persempre907 [ Sun Jan 07, 2007 5:03 pm ] |
| Post subject: | Re: Paso magazine articles and other downloads |
| Author: | paso750 [ Sun Jan 07, 2007 5:07 pm ] |
| Post subject: | |
| Author: | persempre907 [ Sun Jan 07, 2007 5:10 pm ] |
| Post subject: | |
| Author: | Marinus [ Sun Jan 07, 2007 7:28 pm ] |
| Post subject: | Thanks Gerhard. You rock!!!!!!!!!!!!!!1 |
| Author: | paso750 [ Mon Jan 08, 2007 8:43 pm ] |
| Post subject: | |
updated btw. if anyone is interested in the original magazines (as a bulk, maybe per language) contact me via PM. Guess it won`t be interesting for guys outside Europe though due to shipping cost. |
| Author: | jcslocum [ Tue Jan 09, 2007 3:42 am ] |
| Author: | paso750 [ Tue Jan 09, 2007 10:02 am ] |
| Post subject: | |
| Author: | Rogero [ Wed Feb 14, 2007 11:39 pm ] |
| Post subject: | |
| Author: | ducapaso [ Sat Mar 10, 2007 8:39 am ] |
| Post subject: | |
| Author: | paso750 [ Tue Mar 13, 2007 9:48 pm ] |
| Post subject: | |
| Author: | paso750 [ Wed Mar 14, 2007 9:18 pm ] |
| Post subject: | |
thanks to Hårvard (h1a) added colour 907ie wiring diagram (in higher res as in the post in the 907ie section) |
| Author: | paso750 [ Tue Apr 03, 2007 7:34 pm ] |
| Post subject: | |
| Author: | Rogero [ Thu Apr 19, 2007 6:50 am ] |
| Post subject: | |
| Author: | ducapiero [ Thu Apr 19, 2007 9:35 am ] |
| Post subject: | |
| Page 1 of 9 | All times are UTC |
