ducatipaso.org • View topic - Engine ready to go back in
It is currently Sun Jun 21, 2026 6:49 am
 Post subject: Engine ready to go back in
PostPosted: Sun Jan 02, 2005 3:52 pm
This fall my 750 Paso had a failure of the output (sprocket) shaft bearing. I picked up a used bottom end and just finished transferring all of the parts from the other engine over. I hope to get the engine back into the frame today and maybe get her running tomorrow.
I may take the old engine apart to see just how much damage has been caused by the failure. From what I can see from the outside and by looking into the engine now that the pistons are out, there is very little loose metal in there.
PostPosted: Sun Jan 02, 2005 6:07 pm
So you've got your barrels, pistons, and heads on a new (used) bottom end and gearbox, eh Jon? Did you set new ignition timing on the new bottom end, or are you just going to see how the new one feels? Let us know how it goes.
I have found the *sweet spot* on my chain again at just on 25mm slack, and once again have a total absence of vibration.
PostPosted: Sun Jan 02, 2005 10:09 pm
PostPosted: Sun Jan 02, 2005 11:34 pm
PostPosted: Mon Jan 03, 2005 6:17 pm
PostPosted: Mon Jan 03, 2005 6:33 pm
PostPosted: Mon Jan 03, 2005 8:21 pm
PostPosted: Tue Jan 04, 2005 5:22 am
OK, jon, well I hope it FLIES. If she doesn't go as well as she did before, it can only be the timing, eh?
PostPosted: Tue Jan 04, 2005 12:58 pm
PostPosted: Thu Jan 13, 2005 1:54 pm
John,
check out the Haynes stuff in the download section if you want to kow how to adjust the timing.
It`s not for the Paso but the engines of Monster/SS are about the same.
Gerhard
PostPosted: Sat Jan 15, 2005 4:13 am
Gerhard,
Glad to see you've made it over from the mail list. I still do both.
I'll download the haynes info and check it out. It would be nice to do a static timing before putting it in and having it running. Thanks.
