| mounting exhaust connection http://ducatipaso.org/forum/viewtopic.php?f=1&t=1571 |
| Author: | ducapiero [ Mon Jan 22, 2007 9:33 pm ] |
| Post subject: | mounting exhaust connection |
Hi guys in this period i plan to mount new 2 in 1 collector,i buy two new gaskets,but i don't understand how i have to recover the ring that hold the exhaust on the cilinder... :confused: :confused: :confused: give me the light for this upgrade Piero P.S. i chose a carby arrow at 45 angle |
| Author: | ducapiero [ Wed Jan 24, 2007 4:43 pm ] |
| Post subject: | |
help me i don't know how to procede!!!! |
| Author: | Desmo_Demon [ Wed Jan 24, 2007 5:45 pm ] |
| Post subject: | |
I don't understand what you are asking. Are you wanting to know how to remove the retaining ring from the head or how to remove the ring from the exhaust pipe? To remove it from the head, you just remove the two nuts that are mounted on the head studs and wiggle it off the studs. In some cases, I've seen the nuts to be over-torqued, which results in the ring being bent and stubborn to come off. Heavy rust could cause problems pulling it off of the studs, also. To remove the retaining ring from the pipe, you just separate the ring from the flange on the exhaust pipe, and the two half-rings will fall out. If they are badly rusted, they may be sticking, but shouldn't be a problem to get off. Once the half-rings are removed, the ring just slides off the pipe. Did I answer your question? |
| Author: | ducapiero [ Wed Jan 24, 2007 8:36 pm ] |
| Post subject: | |
demon i want to separate the lock ring from the exhaust pipe,on my manual there can be 4 pieces i think.but on my bike i don't see this....mine paso is of 88 on the new exhaust there isn't lock ring.... :confused: :confused: :confused: :confused: :confused: |
| Author: | Desmo_Demon [ Wed Jan 24, 2007 9:21 pm ] |
| Post subject: | |
