ducatipaso.org • View topic - Checking the timing
It is currently Sat Jun 20, 2026 12:35 am
 Post subject: Checking the timing
PostPosted: Tue Feb 13, 2007 3:33 pm
PostPosted: Tue Feb 13, 2007 7:35 pm
The jumping mark at low RPM is probably caused by ignition misfire. I will guess that you are using an inductive pickup timing light, not one inline. The misfire can be caused by a few things so you will need to do some checking of the wiring and the high tension leads.
What's the voltage at the coils at low RPM? High RPM?
How old are the HT leads.
Users browsing this forum: No registered users and 26 guests
