ducatipaso.org • View topic - New menber
It is currently Wed Jun 17, 2026 12:31 am
 Post subject: New menber
PostPosted: Fri Feb 09, 2007 8:34 pm
Hello Paso Forum,
I am Karel from the Netherlands and have just bought a Paso.
It was very cheap €200, see picture.
It looks very bad, but need a bit of work.
So I can now make the Paso a special bike.
It will become an naked Paso.
The original engine is dead, now I have and ST2 engine in the Paso.
The Paso needs new paint and then put together.
I can put more pictures when I am rebuilding the bike.
Greetings,
Karel.
So I have bought the Paso.
Two parts more:
PostPosted: Fri Feb 09, 2007 9:39 pm
Welcome to the board!
I'm sure you can get a lot of assistance from the members of this board with your new project. An ST2 engine in a Paso sounds like an interesting engine swap. Installing some upside-down Showa forks and 17" wheels with 320mm Brembo rotors and calipers would make for some more additional improvements.
I'm currently working on a functional restoration of my Paso, and hoping to do some upgrading once I get it back running and on the road for a few thousand miles.
http://members.aol.com/TBoling125/vicks_paso.html
I wish you luck with your Paso Project!
Edit - What kind of brake rotors are on the front wheel? They don't look like the rotors on my Paso.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Fri Feb 09, 2007 10:54 pm
PostPosted: Sat Feb 10, 2007 11:17 am
Welcome Karel!
That ST2 engine in 750 paso frame is very intresting project, but have U measured, that front wheen dont hit to engine, sorry to radiator, if need to brake very hardly? :confused: Where/how U are planning to put radiator? Anyway, Your Paso need after that modification ALSO update to front brakes... How You swap M16 ECU to Paso electrics??? ST2 harness??? As U see, many very intresting questions... :laugh:
PostPosted: Sat Feb 10, 2007 1:23 pm
Hallo,
I put here some pictures so you can see it.
I also use the complete ST2 harness, ST2 throttle body's, ST 2 Clocks Speedo and Revcounter, ST2 handle bar switches, ST2 rectifier regulator and more.
It will become a Naked Paso ST2.
I am now making every thing to fit well.
So may be next week it can go for some new paint.
Greeting,
Mister naked Paso ST2
PostPosted: Sat Feb 10, 2007 1:34 pm
Very interesting :thumbup: :thumbup: :thumbup: , but also huge work to made all that stuff.
Caution with the front wheel, it really could hit the radiator.
Having to do all that work, perhaps I would have fixed a desmoquattro engine :lick: :lick: :lick: .
Let us see your progress.
PostPosted: Sat Feb 10, 2007 9:07 pm
From where You get that flat radiador, cause ST2 have curved one? I think, U need curved radiator, that it dont hit to front wheel in hard braking.... :confused:
How U planned to solve airbox system? Does ST airbox fit under Paso fuel tank? Air feed to airbox?
Frankie: better/much easier to find some Desmoquatro, like 851/888/ST4, but if go to 851/888 series, then ONLY some SP modells... :evil:
PostPosted: Sat Feb 10, 2007 9:17 pm
[quote="karel"]
So, it will be VERY CLOSE to 907IE(Paso) with big bore kit (944cc with ST2 cylinders and pistons), but naked... :laugh:
PostPosted: Sat Feb 10, 2007 9:44 pm
PostPosted: Sun Feb 11, 2007 12:34 pm
PostPosted: Sun Feb 11, 2007 1:23 pm
PostPosted: Mon Feb 12, 2007 2:47 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Mon Feb 12, 2007 6:01 pm
PostPosted: Mon Feb 12, 2007 6:04 pm
