| Checking the timing http://ducatipaso.org/forum/viewtopic.php?f=1&t=1599 |
| Author: | betenoire [ Tue Feb 13, 2007 3:33 pm ] |
| Post subject: | Checking the timing |
| Author: | jcslocum [ Tue Feb 13, 2007 7:35 pm ] |
| Post subject: | |
The jumping mark at low RPM is probably caused by ignition misfire. I will guess that you are using an inductive pickup timing light, not one inline. The misfire can be caused by a few things so you will need to do some checking of the wiring and the high tension leads. What's the voltage at the coils at low RPM? High RPM? How old are the HT leads. |
