| Tyre choice ??????? http://ducatipaso.org/forum/viewtopic.php?f=1&t=1618 |
| Author: | nilaus [ Fri Feb 23, 2007 10:40 am ] |
| Post subject: | Tyre choice ??????? |
Hey PASO’ist. I am in a situation that I need to change my front tyre. I am lucky to have a dealer near me home has the original Michilin tyre 130 / 60 – 16 in stock to an reasonable price. But I am also considering a new design of tyre, but with know compromise of another tyre dim. 130 / 70 – 16. What is your adveice, sticking to the original or going for an newer tyre design but with a higher profile. If the new design, which make and type would you recommend. Regards Klaus Denmark PASO 750, 1990. |
| Author: | persempre907 [ Fri Feb 23, 2007 1:55 pm ] |
| Post subject: | |
Original type, no doubt!!! Ciao |
| Author: | paso750 [ Fri Feb 23, 2007 2:13 pm ] |
| Post subject: | |
Klaus, I never tried different tires yet, but according to a file I found in the internet in Germany there`s an official tire approval which lists a Michelin 130/70ZR16 Macadam 90x I don`t know if this helps as this model is not produced any longer but the successor is the 100x, which also exists in that size. G. |
| Author: | Duc750 [ Fri Feb 23, 2007 5:15 pm ] |
| Post subject: | |
The Mac 100's are not listed in those sizes on Michelin UK http://two-wheels.michelin.com/2w/front ... 03&lang=EN But they are in atleast some of the common alternative sizes that shouldn't require much modification. They are quite a long lasting tyre and not exactly at the cutting edge but then neither are the M59 A 59 tyres ! |
| Author: | paso750 [ Fri Feb 23, 2007 6:35 pm ] |
| Post subject: | |
I found the 100X in that size on a webpage of an online tire supplier. May have been a typo |
| Author: | Duc750 [ Mon Feb 26, 2007 10:09 pm ] |
| Post subject: | |
Michelin UK don't always carry the same range as mainland Europe for some reason so They may be avaialble in Germany in that size |
