It is currently Tue Sep 30, 2025 12:29 am
[ 3 posts ] |
Author |
ducapiero
Post subject: mounting exhaust gaskets Posted: Sun Mar 11, 2007 6:50 pm |
Joined: Mon Dec 11, 2006 12:00 am Posts: 178 Location: Italy
year: 1985
Hi guys yesterday i mount the 2 in 1 pipe ,but i 'm not sure about the exhaust gasket position what side i have put in face of cilinder???
P.S.
i don't find the old gasket,in fact both pipe leaking oil.....
i'ts possible that they were burned for the long time of using???'
may thanks
Piero
Top |
ducapaso
Post subject: Posted: Sun Mar 11, 2007 8:32 pm |
paso grand pooh-bah |
Joined: Sun Aug 01, 2004 12:00 am Posts: 1097 Location: siena, italy
My "dukess" has a 2 in 1 pipe and it needs special spacer (about 5/8") to put in the assembly (I don't remember if they're between the head and the pipe or backward the pipe, before the iron ring lock). When I put them in the wrong position I wasn't able to assemble the complete exaust, as the vertical pipe wasn't in the right position.
You might have the same trouble with your 2 in 1
However, you need gaskets between pipes and heads.
[now the same in italian] :thumbup:
Sulla mia "dukess" c'è un 2 in 1 che richiede degli anelli distanziali su misura ( di otto millimetri circa, ma non ricordo se vanno tra il tubo di scarico e la testa o sopra lo scrico, prima dell'anello di chiusura). quando li ho montati nella posizione sbagliata, il tubo del cilindro verticale non mi stava in posizione e forse tu potresti avere lo stesso problema.
Comunque ti serve una guarnizione tra testa e tubo.
_________________ have a nice ride, Nicola
Black "DUKE" 751582 ex...Red "smooth" 753349
Top |
ducapiero
Post subject: Posted: Sun Mar 11, 2007 9:41 pm |
year: 1985
a me non ha dato problemi di montaggio volevo sapere se bisognava fare qualche procedura prima d'inserire le guanrnizioni...
si può dire che l'installazione è stata abbastanza Pulita :thumbup:
I don't have thi s problem on my bike
i want to know how to position correctly the gasket without damaging anything....
the instalation is at this point so smooth :thumbup:
(i hope i translate well)
Top |
[ 3 posts ] |
Users browsing this forum: No registered users and 118 guests |
