| mounting exhaust gaskets http://ducatipaso.org/forum/viewtopic.php?f=1&t=1642 |
| Author: | ducapiero [ Sun Mar 11, 2007 6:50 pm ] |
| Post subject: | mounting exhaust gaskets |
Hi guys yesterday i mount the 2 in 1 pipe ,but i 'm not sure about the exhaust gasket position what side i have put in face of cilinder??? P.S. i don't find the old gasket,in fact both pipe leaking oil..... i'ts possible that they were burned for the long time of using???' may thanks Piero |
| Author: | ducapaso [ Sun Mar 11, 2007 8:32 pm ] |
| Post subject: | |
My "dukess" has a 2 in 1 pipe and it needs special spacer (about 5/8") to put in the assembly (I don't remember if they're between the head and the pipe or backward the pipe, before the iron ring lock). When I put them in the wrong position I wasn't able to assemble the complete exaust, as the vertical pipe wasn't in the right position. You might have the same trouble with your 2 in 1 However, you need gaskets between pipes and heads. [now the same in italian] :thumbup: Sulla mia "dukess" c'è un 2 in 1 che richiede degli anelli distanziali su misura ( di otto millimetri circa, ma non ricordo se vanno tra il tubo di scarico e la testa o sopra lo scrico, prima dell'anello di chiusura). quando li ho montati nella posizione sbagliata, il tubo del cilindro verticale non mi stava in posizione e forse tu potresti avere lo stesso problema. Comunque ti serve una guarnizione tra testa e tubo. |
| Author: | ducapiero [ Sun Mar 11, 2007 9:41 pm ] |
| Post subject: | |
a me non ha dato problemi di montaggio volevo sapere se bisognava fare qualche procedura prima d'inserire le guanrnizioni... si può dire che l'installazione è stata abbastanza Pulita :thumbup: I don't have thi s problem on my bike i want to know how to position correctly the gasket without damaging anything.... the instalation is at this point so smooth :thumbup: (i hope i translate well) |
