ducatipaso.org • View topic - fuel indicator
It is currently Thu Jun 18, 2026 5:20 pm
 Post subject: fuel indicator
PostPosted: Wed Apr 11, 2007 12:20 pm
year: 1985
Hi guys i finished to mount my lcd cockpit but i can't be able to make function the fuel indicator.
from my electrical plan there are three wires come out from the tank indicator:
Black-ground
Violet-reserve fuel signal
Pink-fuel level
i think thesre are correct,isn't it??
i'm thinkig uder the tank they are badly coonnected i post a photo to give you an idea of what i see near the indicator
[img][img]http://i172.photobucket.com/albums/w10/madpiero/IMG_0036.jpg[/img][/img]
give me the light
thans
Piero
[/quote]
PostPosted: Wed Apr 11, 2007 2:50 pm
I have just now my 750 Paso tank "open" and i have in my hand that "sender unit", like Your foto: U have JUST RIGHT connnections in Your sender unit, but surely check all those 3 connectors, that they are free from any shit/dust/corrosion, etc... I think, Your problem is some other, than sender unit.
Is it possible, that U send enough details about Your dashboard here, what U are using???? I am very courious, whatkind unit U try to use now.... U mention only, that "lcd cockpit" :confused: :confused: :confused: It can be, that Your unit CANT work with Paso sender unit.... :evil:
PostPosted: Wed Apr 11, 2007 8:51 pm
year: 1985
I am using an acewell cockpit with many function....
one of these is fuel level....
i want to use it!!!! :sad:
any suggestion??????? :confused: :confused:
[img][img]http://i172.photobucket.com/albums/w10/madpiero/IMG_0042.jpg[/img][/img]
PostPosted: Thu Apr 12, 2007 7:47 am
Piero,
Antti only can help you :D !!!
No matter what, very nice cockpit :lick: :lick: :lick: !
PostPosted: Thu Apr 12, 2007 3:48 pm
PostPosted: Thu Apr 12, 2007 4:17 pm
year: 1985
PostPosted: Thu Apr 12, 2007 4:43 pm
PostPosted: Thu Apr 12, 2007 7:48 pm
PostPosted: Thu Apr 12, 2007 7:51 pm
year: 1985
PostPosted: Fri Apr 13, 2007 7:10 am
PostPosted: Fri Apr 13, 2007 8:55 am
year: 1985
PostPosted: Fri Apr 13, 2007 10:05 am
PostPosted: Fri Apr 13, 2007 2:55 pm
year: 1985
Annti i find the mistake!!! :thumbup:
the cable under the tank were wrong positioned
i checked with the tester the two cable of the tank sender
and i foun the tricky wires,
one is on off (LIGHT),the othe is connected to the resistance(LEVEL)
now i changed the pink and the violet wire position and all function...... :thumbup: :thumbup: :thumbup: :thumbup:
PostPosted: Fri Apr 13, 2007 3:05 pm
Very good !!!! :thumbup: Soon You are our "fuel level specialist"!!! :laugh: Especially, when You find out, how accurate that Your new dashboards fuel meter is. Let us know, how function.... Did You have any other problems with new dashboard, or was all other connections easy to do? How it measures speed, water temp and rpm ??? Other warning lights? Is there good instruction manuals with new dashboard package?
Take some close fotos, when U have put it to Paso. I am very courious, how it looks and fit to Paso dash place... :thumbup:
PostPosted: Sat Apr 14, 2007 9:43 am
year: 1985
