| Swingarm Bearings, Seals, and Spacers http://ducatipaso.org/forum/viewtopic.php?f=1&t=1685 |
| Author: | Desmo_Demon [ Thu Apr 12, 2007 3:48 pm ] |
| Post subject: | Swingarm Bearings, Seals, and Spacers |
| Author: | Desmo_Demon [ Thu Apr 12, 2007 3:49 pm ] |
| Post subject: | |
| Author: | Desmo_Demon [ Thu Apr 12, 2007 3:50 pm ] |
| Post subject: | |
| Author: | Finnpaso [ Thu Apr 12, 2007 3:56 pm ] |
| Post subject: | |
| Author: | Desmo_Demon [ Thu Apr 12, 2007 4:09 pm ] |
| Post subject: | |
| Author: | Finnpaso [ Thu Apr 12, 2007 4:21 pm ] |
| Post subject: | |
| Author: | persempre907 [ Thu Apr 12, 2007 7:07 pm ] |
| Post subject: | |
| Author: | Desmo_Demon [ Fri Apr 13, 2007 2:05 pm ] |
| Post subject: | |
General Electric is always hiring.....just not for the easy jobs like what I have. :laugh: Here is a picture of all the swingarm components from the brake side. I have them laid out as they would be mounted in the swingarm. The inner and outter race support spacers are one on top of the other, but the inner spacer actually goes inside the outer spacer (naturally).... |
| Author: | Finnpaso [ Fri Apr 13, 2007 3:09 pm ] |
| Post subject: | |
Looks exact, how it should be... :thumbup: |
| Author: | paso750 [ Fri Apr 13, 2007 7:17 pm ] |
| Post subject: | |
| Author: | paso750 [ Fri Apr 13, 2007 7:26 pm ] |
| Post subject: | |
| Author: | Desmo_Demon [ Mon Apr 16, 2007 12:35 pm ] |
| Post subject: | |
| Author: | paso750 [ Sat Apr 21, 2007 6:24 pm ] |
| Post subject: | |
ok, finally continued and removed the bearings. On the 2 needle bearings on the left swingarm side it says: HK 2520 INA WX (outer diameter 32mm, width 20mm, inner diameter 25mm) http://www.consbrgs.com/page.taf?detail=196_1_39 On the 2 needle bearings which are mounted where the shock linkage connects it says: HK 2020 INA WX (outer diameter 26mm,width 20mm, inner diameter 20mm) http://www.consbrgs.com/page.taf?detail=196_1_31 http://www.bearingcie.com/needle_bearin ... motive.htm To remove the bearings (the ones in the front) I used a 24 and a 30mm wrench nut which both fitted by millimeter in the swingarm holes. Note that the parts manual at the linkage mount of the swingarm shows (30) spacer and (28) washer. Both pieces where not there. While the washer may just have missed there cannot be a spacer because the step that stops the bearing when it`s pressed back in place is part of the swingarm. A spacer would only be required if the hole where the bearings are would have the same diameter through it`s whole length instead in the middle section the diameter is smaller. At last I received the new seals for the linkage. The package says: 075549265 Anello Tenuta ST4-900M-SS/03 There`s no printing on the seals at all. Measures are: outer diameter: 26,16mm inner diameter: 19mm height 4mm type is B1OF (single sided metal housing w/o spring) PS: a good page to look up bearings, listing alternative types from different manufacturers is: http://www.consbrgs.com/html/catalog3.html unluckily there`s no search function so you`ll have to click "forward until you find what you`re looking for. |
| Author: | paso750 [ Tue Apr 24, 2007 7:15 pm ] |
| Post subject: | |
| Author: | paso750 [ Mon Mar 03, 2008 6:18 pm ] |
| Post subject: | Re: Swingarm Bearings, Seals, and Spacers |
the 2 bearings in the sprocket carrier are: SKF 6005-2RS1 / C3 (in the 750 Sport these are: SKF 6204-2RS1 / C3) G. |
