Wiring upgrade Choke/ idle issue http://ducatipaso.org/forum/viewtopic.php?f=1&t=1723 |
Author: | staticvoid1975 [ Wed May 09, 2007 5:59 am ] |
Post subject: | Wiring upgrade Choke/ idle issue |
Author: | jcslocum [ Wed May 09, 2007 12:17 pm ] |
Post subject: | |
Author: | ducapaso [ Wed May 09, 2007 3:54 pm ] |
Post subject: | |
Author: | staticvoid1975 [ Fri May 11, 2007 3:33 am ] |
Post subject: | hmmm |
Author: | persempre907 [ Fri May 11, 2007 4:26 pm ] |
Post subject: | |
Author: | Finnpaso [ Fri May 11, 2007 8:21 pm ] |
Post subject: | |
Author: | staticvoid1975 [ Fri May 11, 2007 11:31 pm ] |
Post subject: | ordered |
Author: | persempre907 [ Sat May 12, 2007 8:45 am ] |
Post subject: | |
Author: | streetsurfer [ Sat May 12, 2007 3:11 pm ] |
Post subject: | |
Author: | staticvoid1975 [ Sun May 13, 2007 10:56 pm ] |
Post subject: | |
I am not sure what caused the rpm drops. I was getting a reading of 11.8 to each coil and there was equal pressure coming out of the exhausts. I will try the wiring mod again once the regulator/ wiring situation is tamed. |
Author: | jcslocum [ Mon May 14, 2007 7:25 pm ] |
Post subject: | |
There is a crossover in the exhaust, so checking the end of the muffler to see if one cylinder is running doesn't work. |
Author: | streetsurfer [ Mon May 14, 2007 7:51 pm ] |
Post subject: | |
Yes, better to check the temperature of the header pipes (before the X). |
