| Questions http://ducatipaso.org/forum/viewtopic.php?f=1&t=178 |
| Author: | pompone [ Mon Jan 31, 2005 11:56 pm ] |
| Post subject: | Questions |
| Author: | Skins [ Tue Feb 01, 2005 7:47 pm ] |
| Post subject: | |
| Author: | pompone [ Tue Feb 01, 2005 9:10 pm ] |
| Post subject: | |
| Author: | mike [ Tue Feb 01, 2005 9:42 pm ] |
| Post subject: | |
i have a friend that has the dual-pot brembos on his bike. it's done with a caliper adapter like this one (this is nicolas bike) |
| Author: | paso750 [ Wed Feb 02, 2005 8:59 am ] |
| Post subject: | |
I use a simple Bitubo shock. Can`t say anything bad about it. It was the cheapest replacement i found a couple of years ago. For me it is a little bit to hard, but the spring tension is easily adjustible. The only "problem" with this shock is that the rebound adjustment lever is on the bottom. The lever is a little bit too long and touches the shock leverage. As this is just a screw with a plastic cap on it`s head it`s easy to remove and shorten it. Just be careful to make a mark wat which position the adjuster exactly was when you remove the screw so you get to the exact same position when you reassemble it. After about 4 years the paint of the shock is a bit bubbly and coming off on top. Maybe this is because of low paint quality in combination with the heat from the rear header, I don`t know. Anyway I think it`s o.k. and as the price is only a part of what the original new part costs it`s even better Onve in a while you`ll find an original shock on ebay. Check ebay.de there was one a couple of days ago. Gerhard |
| Author: | pompone [ Wed Feb 02, 2005 9:53 pm ] |
| Post subject: | |
Thank you Gerhard. I'm thinking to buy a new Bitubo shock now. |
| Author: | ducapaso [ Mon Feb 28, 2005 4:32 pm ] |
| Post subject: | |
did anybody calling me? I fit on my dukess 17" rims and 320 disks, so I had just to fit the calipers in the right point... But if you still have the original brake disks i think you'll not find a pad that can fit well on your brake disk. Otherwise you can search for 280mm floating brake disk for 16" rim and work on these Have a nice ride, Nicola |
| Author: | ducapaso [ Fri Mar 18, 2005 6:25 pm ] |
| Post subject: | post script |
