Starter...why???? http://ducatipaso.org/forum/viewtopic.php?f=1&t=1806 |
Page 1 of 2 |
Author: | ducapiero [ Sun Jun 17, 2007 12:40 pm ] |
Post subject: | Starter...why???? |
Guys yestaday i was coming back home i turned on my baby and all is ok ,then i turnde on another time and,...nothing :rant: :rant: :rant: ![]() ![]() i say all the baddwords in the world iand i ha ve t push her to come back home,Today i check all the wire and connection,ui hope is a bad connectuion.... give me suggestion please i want to go to wdw 2007!!!!1 ![]() ![]() |
Author: | persempre907 [ Sun Jun 17, 2007 5:34 pm ] |
Post subject: | |
Ciao Piero, il motorino d'avviamento gira per caso a vuoto? Se è così è la ruota libera dell'avviamento e ti tocca smontare il carter laterale. Se non gira proprio può essere di tutto, dal fusibile a... Hi Piero, Does the starter work freely, but doesn't the engine start? If so, the freewheel was broken, and you have to remove the left case of the engine. If the starter doesn't work at all, it could be any issue, from a fuse to... Ciao |
Author: | ducapiero [ Mon Jun 18, 2007 12:38 pm ] |
Post subject: | |
it' the starter going mad yesterday i give it little hammer on and it function antoher time.... i think the brushes are k.o. do you have any experience i'm very scared by cost ![]() ![]() |
Author: | persempre907 [ Mon Jun 18, 2007 12:52 pm ] |
Post subject: | |
Don't worry Piero. The brushes are inexpensive at all. Besides, you can fit any kind of brush, it's enough they are bigger than the stock ones: you have only to reduce them to the right shape. Good work. Ciao |
Author: | jcslocum [ Tue Jun 19, 2007 12:23 am ] |
Post subject: | |
Author: | ducapaso [ Tue Jun 19, 2007 8:47 pm ] |
Post subject: | |
Author: | ducapiero [ Tue Jun 19, 2007 11:33 pm ] |
Post subject: | |
Author: | ducapaso [ Wed Jun 20, 2007 6:28 pm ] |
Post subject: | |
Author: | ducapiero [ Wed Jun 20, 2007 6:53 pm ] |
Post subject: | |
Author: | persempre907 [ Wed Jun 20, 2007 7:23 pm ] |
Post subject: | |
Author: | ducapaso [ Fri Jun 22, 2007 5:59 pm ] |
Post subject: | |
Author: | persempre907 [ Fri Jun 22, 2007 7:38 pm ] |
Post subject: | |
Author: | ducapaso [ Sat Jun 23, 2007 5:14 am ] |
Post subject: | |
Author: | persempre907 [ Sat Jun 23, 2007 1:43 pm ] |
Post subject: | |
:neener: :neener: :neener: :neener: :neener: :neener: I wanted only suggest him to bring himself a calendar, in case he had forgotten some Saint to swear at (here in Italy, on the calendars there is a Saint for every day). :neener: :neener: :neener: :neener: :neener: :neener: Ciao P.S. This is my post n. 907 :thumbup: :funny: |
Author: | ducapaso [ Mon Jun 25, 2007 3:53 pm ] |
Post subject: | |
Page 1 of 2 | All times are UTC |
