| Weber diassembly http://ducatipaso.org/forum/viewtopic.php?f=1&t=1809 |
| Author: | sprintex [ Mon Jun 18, 2007 1:29 pm ] |
| Post subject: | Weber diassembly |
Ok I'm looking at the Weber, removed the three screws on top , two in front in in the rear, which I think should remove the top of the carburator so I can get into the float bowl, but it is solid. Do I have to remove from bike to take it apart? |
| Author: | jfiore [ Mon Jun 18, 2007 4:50 pm ] |
| Post subject: | Weber Disassembly |
There are four screws on the top of the carburetor, one at the back center, one at the left front, and two at the right front, one of them in front of the fuel inlet, one of them behind the fuel inlet. You may have to lightly tap the cover to loosen it once the screws are removed, depending on how long it has been since it was previously dis-assembled. There is a download on this web site of an exploded view of the 44 DCNF carb, which will help you to see where all the parts are. Good Luck! |
| Author: | sprintex [ Mon Jun 18, 2007 5:49 pm ] |
| Post subject: | |
Ok I must have missed on of the right fronts. Small world. I'm working in Windsor above Webster bank today. Thanks |
| Author: | sprintex [ Mon Jun 18, 2007 5:59 pm ] |
| Post subject: | her it is |
http://s211.photobucket.com/albums/bb17 ... G_0088.jpg Looks great, will not run. Was off the road for three years. Was well taken care of. |
| Author: | streetsurfer [ Mon Jun 18, 2007 7:42 pm ] |
| Post subject: | |
| Author: | sprintex [ Mon Jun 18, 2007 7:56 pm ] |
| Post subject: | |
| Author: | jcslocum [ Tue Jun 19, 2007 12:27 am ] |
| Post subject: | |
| Author: | sprintex [ Tue Jun 19, 2007 1:43 am ] |
| Post subject: | |
| Author: | jcslocum [ Tue Jun 19, 2007 2:26 am ] |
| Post subject: | |
