It is currently Sat Jun 20, 2026 2:43 am
[ 13 posts ] |
| Author |
yellerduck
Post subject: Jet size for Dellort PHF 36 Posted: Sun Jan 07, 2007 1:40 am |
| Top |
ducinthebay
Post subject: Dellorto Jetting Posted: Fri Jan 12, 2007 5:01 am |
| paso grand pooh-bah |
| Top |
yellerduck
Post subject: Re: Dellorto Jetting Posted: Tue Jan 23, 2007 4:30 am |
| Top |
ducinthebay
Post subject: Posted: Tue Jan 23, 2007 4:55 am |
| Top |
yellerduck
Post subject: Posted: Tue Jan 23, 2007 2:33 pm |
| Top |
Post subject: Posted: Tue Jan 23, 2007 3:14 pm |
the Champion plugs are the RA6HC.
In my Paso these worked better than all other plugs I tried from Nippon Denso to NGK, NGK plat.
In case you didn`t do it yet the often posted wiring mod may be of some help. (although not the solution of backfiring)
The rubber sockets between inlet manifold and carb are ok ?
| Top |
yellerduck
Post subject: Posted: Tue Jan 23, 2007 8:00 pm |
| Top |
yellerduck
Post subject: RUNNING RICH, NEED ADVICE Posted: Sun Jul 01, 2007 2:48 pm |
| Top |
ducinthebay
Post subject: Posted: Sun Jul 01, 2007 7:35 pm |
Make sure that you are running a return line from your carbs back into the tank. The Sport has to run a fuel pump, and the pump will easily overpower your floats and make your bike run really rich. Run a T to run the excess pressure back into the tank, then another T to split between the two carbs. On the Sport there are two outlets near the middle of the tank. One is the return line, the other is the vent.
Have you checked your float levels?
| Top |
yellerduck
Post subject: Posted: Sun Jul 01, 2007 9:16 pm |
| Top |
ducinthebay
Post subject: Posted: Mon Jul 02, 2007 12:25 am |
| Top |
[ 13 posts ] |
Users browsing this forum: No registered users and 19 guests |
