| No oil , charge light, http://ducatipaso.org/forum/viewtopic.php?f=1&t=1833 |
| Author: | sprintex [ Tue Jun 26, 2007 4:17 pm ] |
| Post subject: | No oil , charge light, |
On my new to me 88 Blue Paso the oil and charging lights do not work. I cleaned the contacts on the back side of the instrument panel. I am not getting any voltage to them, I check with a meter. I got all the other lights to work with a good cleaning. Any Ideas,those are the two lights I would like to have. |
| Author: | ducapaso [ Tue Jun 26, 2007 5:26 pm ] |
| Post subject: | |
I happened to have the +12v "line" broken in the circuit in the backward of the instrument panel. Anyway, you can try to put the plug pon the oil bulb in contact straight to the frame (12v ground). This will tell you something about bulb and ground wire |
| Author: | Finnpaso [ Tue Jun 26, 2007 6:25 pm ] |
| Post subject: | |
That printed circuit behind dashboard can broke quite easily, but all contact surfaces in it must be out of all oxygen and totally clean. U can use multimeter in resistance scale to check continuty. Remember to clean well those bulb contact areas and easy to check also those bulbs in resistance scale. :thumbup: |
| Author: | Desmo_Demon [ Wed Jun 27, 2007 11:56 am ] |
| Post subject: | |
| Author: | sprintex [ Wed Jun 27, 2007 12:41 pm ] |
| Post subject: | |
| Author: | PaulD [ Thu Jun 28, 2007 12:05 am ] |
| Post subject: | Charge light |
The charge light does not work because that voltage regulator does not have a provision for it. That regulator was recommended to me by BCM in Laconia when the stock one failed. I figured it was a small sacrifice for a more dependable unit. Sorry, I had forgotten all about the light. |
| Author: | sprintex [ Thu Jun 28, 2007 1:46 am ] |
| Post subject: | |
Thanks Paul. I forgot you had mentioned that. You would have gotten a good chuckle when the Paso started, it blew sunflower seeds like a confetti gun out of the mufflers. Guess you have a couple of mice in the garage. :laugh: |
| Author: | PaulD [ Fri Jun 29, 2007 12:37 am ] |
| Post subject: | |
I learned my lesson when a mouse got into the glove box of the AMX. |
