ducatipaso.org • View topic - Wiring upgrade
It is currently Sun Jun 21, 2026 7:54 am
 Post subject: Wiring upgrade
PostPosted: Wed Sep 19, 2007 4:28 pm
Hi John, just tried your upgrade with relays, but without success.
All circuits went dead!
I've gone back to standard and although I now have power restored, I still have the original non-starting problem.
My bike differs slightly from yours, in that it has TWO coils, one on each side rail. Would this make it unsuitable for your mod?
Steve
PostPosted: Wed Sep 19, 2007 11:49 pm
Nope, they are the same. I have 2 coils too.
You had no power at all?
 Post subject: Dead Paso
PostPosted: Thu Sep 20, 2007 12:17 am
Hi Jon
Absolutely dead as a DODO! No power to instrument console,no sign of life at starter solenoid, not even a click!
I'm certain I followed your instructions, I had the print-out beside me as I worked.
The coils were the only difference to your photos, I just made up a "Y" wire and put one on each coil and took the ORANGE wire to the relay (terminal 86 ?)
I got the relays from a local autoelectrician who assured me they would be OK after seeing your upgrade print-out (which I left with him for reference to get my order ready).
They are not genuine Bosch, they are Guardian GR7 12V- 40A/15A. Do you think they could be the cause?
If it stops raining I may venture out and have a look at the starter motor as the solenoid makes a healthy "click" when the starter is pressed but even with the kill switch off and a leisure battery jumping it it wont turn over at all !!
[/i] :sad: :mad: :confused:
Steve
PostPosted: Thu Sep 20, 2007 9:52 am
hmm, it`s actually hard to make a mistake...
PostPosted: Thu Sep 20, 2007 12:23 pm
