ducatipaso.org • View topic - Oil Level Sight Glass
It is currently Sun Sep 28, 2025 9:56 pm
 Post subject: Oil Level Sight Glass
PostPosted: Wed Sep 19, 2007 4:28 pm
One of the many things wrong with my Paso is that the sight glass for checking the oil level is cracked and leaking. I have set out to replace this part, but Ducati has discontinued it some time ago (part #066049183). According to the parts diagram, it is the same part as the ignition timing sight glass (also discontinued), but there is a difference between them. The oil level sight glass has a reflector, but the ignition timing glass does not.
I have set out to find a replacement, but am having difficulties in the great land of non-metric parts. I have been able to find a replacement with appropriate dimensions, but it is made of plastic and not good for temperatures above 160-degrees F (71-degrees C). I found another with all the correct dimensions and temperature rating, except for one dimension......it is an M33 x 1.5 thread instead of the necessary M35-1.5 thread.
Anyway, I just wanted to see if anyone out there may have some leads on a replacement sight glass.
These are the dimensions that I've gotten for the part...
paso750 (Gerhard) has pointed out that a person is selling some on eBay out of the Netherlands, but I'm a cheap bastard and don't want to spend $50 USD plus international shipping for the part (at least not yet). The ones that I have been finding that "almost" work are in the $6-$18 USD range, so I'll pursue this a little bit longer until I give up.
Here's the auction that Gerhard found earlier...
http://cgi.ebay.de/Ducati-Pantah-Sport- ... dZViewItem
PostPosted: Wed Sep 19, 2007 5:08 pm
Can such made with lathe from aluminium??? I think, if find good guy for that, its maybe best solution. Surely that coast also little... :evil:
PostPosted: Fri Sep 21, 2007 3:01 am
PostPosted: Fri Sep 21, 2007 12:43 pm
PostPosted: Sat Sep 22, 2007 9:06 pm
 Post subject: Oil Site glass Idea
PostPosted: Sat Sep 22, 2007 10:18 pm
RADDUCK
02 Honda RC51 SP2
87 Paso 750 - Dropped but ride-able
03 Triumph Bonneville - Basket case (resto in the works)
88 Porsche 911 Carrera
04 Subaru STI
 Post subject: Re: Oil Site glass Idea
PostPosted: Mon Sep 24, 2007 12:38 pm
PostPosted: Fri Oct 19, 2007 2:22 am
Tim
Port Murray, NJ
1987 Ducati 750 Paso
1995 Ducati 900SS SP
1999 Ducati 996
1998 ST2
2000 Honda RC51
PostPosted: Fri Oct 19, 2007 1:42 pm
