| Oil Level Sight Glass http://ducatipaso.org/forum/viewtopic.php?f=1&t=1994 |
| Author: | Desmo_Demon [ Wed Sep 19, 2007 4:28 pm ] |
| Post subject: | Oil Level Sight Glass |
One of the many things wrong with my Paso is that the sight glass for checking the oil level is cracked and leaking. I have set out to replace this part, but Ducati has discontinued it some time ago (part #066049183). According to the parts diagram, it is the same part as the ignition timing sight glass (also discontinued), but there is a difference between them. The oil level sight glass has a reflector, but the ignition timing glass does not. I have set out to find a replacement, but am having difficulties in the great land of non-metric parts. I have been able to find a replacement with appropriate dimensions, but it is made of plastic and not good for temperatures above 160-degrees F (71-degrees C). I found another with all the correct dimensions and temperature rating, except for one dimension......it is an M33 x 1.5 thread instead of the necessary M35-1.5 thread. Anyway, I just wanted to see if anyone out there may have some leads on a replacement sight glass. These are the dimensions that I've gotten for the part... paso750 (Gerhard) has pointed out that a person is selling some on eBay out of the Netherlands, but I'm a cheap bastard and don't want to spend $50 USD plus international shipping for the part (at least not yet). The ones that I have been finding that "almost" work are in the $6-$18 USD range, so I'll pursue this a little bit longer until I give up. Here's the auction that Gerhard found earlier... http://cgi.ebay.de/Ducati-Pantah-Sport- ... dZViewItem |
| Author: | Finnpaso [ Wed Sep 19, 2007 5:08 pm ] |
| Post subject: | |
Can such made with lathe from aluminium??? I think, if find good guy for that, its maybe best solution. Surely that coast also little... |
| Author: | 20YearOwner [ Fri Sep 21, 2007 3:01 am ] |
| Post subject: | |
| Author: | Desmo_Demon [ Fri Sep 21, 2007 12:43 pm ] |
| Post subject: | |
| Author: | paso750 [ Sat Sep 22, 2007 9:06 pm ] |
| Post subject: | |
| Author: | RADDUCK [ Sat Sep 22, 2007 10:18 pm ] |
| Post subject: | Oil Site glass Idea |
| Author: | Desmo_Demon [ Mon Sep 24, 2007 12:38 pm ] |
| Post subject: | Re: Oil Site glass Idea |
| Author: | wilbur [ Fri Oct 19, 2007 2:22 am ] |
| Post subject: | |
| Author: | Finnpaso [ Fri Oct 19, 2007 1:42 pm ] |
| Post subject: | |
